Topic: Need help with Arduino Nano 3 and Matlab! (Read 994 times) previous topic - next topic
kchientdc
Hi everybody!
Now i am doing a small project with Arduino Nano 3 and Matlab 2007a. Arduino Nano 3 is connected to my laptop via usb.
I used Matlab command:
Code: [Select]
a = arduino;
[code]v = readVoltage(a,'A0');
to read data from a sensor, then i plotted it in the real time, saved data in a variable of array.
to do more signal processing like filter received data...etc, i really need to know the sampling frequency.
So the main question is that:
how can i set the sampling frequency for the command "readVoltage"?
or is there any command that read the data from the Arduino Nano 3 which i can specify the sampling frequency?
thank in advance!
Paul_KD7HB
Where is the Arduino code? That controls the sampling frequency. Reads once per instruction.
Paul
ieee488
Hi everybody!
Code: [Select]
a = arduino;
thank in advance!
Sounds like you need help with Matlab programming.
kchientdc
Paul
Thanks, bro! There is not Arduino code. I code Arduino Nano by Matlab. and here are the code:
%% Connect to Arduino
% Use the arduino command to connect to an Arduino device.
clear all;
a = arduino;
%% Acquire and display live data
figure
h = animatedline;
ax = gca;
ax.YGrid = 'on';
ax.YLim = [-200 4500];
pulsenum = 0;
stop = false;
startTime = datetime('now');
tic
while ~stop
    % Read current voltage value
    vmv = 1000*v;
    t =  datetime('now') - startTime;
    % Get current time
    % Add points to animation
    addpoints(h,datenum(t),vmv)
    title('Acquiring Sensor Data')
    xlabel('Elapsed time (Sec)')
    ylabel('Voltage (mVol)')
    % Update axes
    ax.XLim = datenum([t-seconds(10) t]);
    datetick('x','keeplimits')
    drawnow
    % fprintf('Thoi diem, %s\n', t0);
    % Check stop condition
    stop = readDigitalPin(a,'D13');
    %fprintf('So xung %d\n', pulsenum);
end
kchientdc
So, you mean i should ask in some forum of Matlab coding?
Microzod_
If I recall correctly, there is a specific sketch you upload to the arduino to make it work with Matlabs commands such as the one you have shown.
In that sketch you probably need to make some provisions to enable a certain sample rate, who knows how that function is actually accessing the arduinos ADC.
But that still leaves the question, how to make the arduinos(ATmega328) ADC sample at a particular rate. Guess the datasheet would be a good place to start because I don't think Arduino is supplying a way to control the sample rate, does it?
