Topic: Motor control with TA8428K (Read 2652 times) previous topic - next topic
jonawadl
Nov 29, 2017, 03:01 am Last Edit: Nov 29, 2017, 02:46 pm by jonawadl
Hi all.
I'm a teacher learning to program I have watched some great videos on Youtube and done a few projects involving LEDs and small motors.
Last week my son challenged me to use and arduino to get his old radio shack RC truck going again.
I plan to use an HC-06 bluetooth adapter for now. Probably it will have a shorter range than is desirable, but it will work for the purpose.
I have been able to use the HC-06 to control the car using relays for controlling forward and backward motion, but with the power and speed this thing has On/Off control is not good enough.
I replaced the six wire servo with a regular servo and I think I have figured out how to do the steering but haven't put that into the sketch yet.
I found a brushed motor controller TA8428K.
I have done a lot of reading and watching motor control videos but can't find instructions for this particular controller. It it is missing the "enable" pin that every other one has.
I used instructions from this lesson and this lesson to try and patch together a sketch that would work.
I thought I was doing ok editing the code until I got to the very last row. This row says I have to use the enable pin to control motor speeds. I was hoping to use an analog input on pins 1&2 to control speed and  rotation of the motor, pretty much like a transistor would.
Can anybody tell me if I'm on the right track with this or if I'm completely out of it here. I'm here to learn so anything goes.
I took out all reference to motor B and to the enable pins because my controller does not have them. I got hung up on the last one on the last sentence. Don't know what to do with it.
Code: [Select]
 DroneBot Workshop 2017
 http://dronebotworkshop.com
 // Edited by Jonathan Waldner on Nov.2017 for a relay and a TA8428 Motor driver.
// Motor A
int in1 = 8;
int in2 = 7;
char BluetoothData; // the Bluetooth data received
// Joystick Input
int joyVert = A0; // Vertical
// Motor Speed Values - Start at zero
int MotorSpeed1 = 0;
// Joystick Values - Start at 512 (middle position)
int joyposVert = 50;
 Serial.begin(9600);   // Start Serial Monitor
 // Set all the motor control pins to outputs
 pinMode(in1, OUTPUT);
 pinMode(in2, OUTPUT);
 // Start with motors disabled and direction forward
 // Motor A
 digitalWrite(in1, HIGH);
 digitalWrite(in2, LOW);
 if (Serial.available()){
   BluetoothData=Serial.read(joyVert); //Get Joystick Vertical position from bluetooth
 // Determine if this is a forward or backward motion
 // Do this by reading the Verticle Value
 // Apply results to MotorSpeed and to Direction
 if (joyposVert < 50)
   // This is Backward
   // Set Motor A backward
   digitalWrite(in1, LOW);
   digitalWrite(in2, HIGH);
   //Determine Motor Speeds
   // As we are going backwards we need to reverse readings
   joyposVert = joyposVert - 50; // This produces a negative number
   joyposVert = joyposVert * -1;  // Make the number positive
   MotorSpeed1 = map(joyposVert, 0, 50, 0, 100);
 else if (joyposVert > 50)
   // This is Forward
   // Set Motor A forward
   MotorSpeed1 = map(joyposVert, 52, 100, 0, 48);
   // This is Stopped
   MotorSpeed1 = 0;
 // Adjust to prevent "buzzing" at very low speed
 if (MotorSpeed1 < 8)MotorSpeed1 = 0;
 // Set the motor speeds
 analogWrite(enA, MotorSpeed1);
}[code]
[/code]
Robin2
To make it easier for people to help you please modify your post and use the code button </>
Code: [Select]
so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Your code is too long to make sense of as it is.
I have used the TA8428K in some model train controllers. It needs a PWM signal on one pin for FWD and on the other pin for REV. For that reason it may be different from the examples you have been looking at. For example the L298 is often controlled by applying PWM to the enable pin and using IN1 an IN2 for direction.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
jonawadl
Code: [Select]
...R
Ok. Thanks I edited my first post to reflect the code. I tried going back to edit it right after I posted it but the forum will only allow me to make one post every five minutes. It's a bit of a pain right now.
Ok so if I need PWM for on both those pins, then code will be very different. I will look for examples and see if I can put something together.
Robin2
Thanks for updating the code. However your program is not complete and I am not sure what it missing.
It looks to me like this
Code: [Select]
should be
Code: [Select]
i.e. one less {
But that is not the only problem.
In any case, to control the TA8428K you need something like this
Code: [Select]
if (direction == 'F') {
analogWrite(motorPinA, 0);
analogWrite(motorPinB, motorSpeed);
else {
analogWrite(motorPinB, 0);
analogWrite(motorPinA, motorSpeed);
Note that it turns off one pin before turning on the other. I can't recall if the chip would be damaged by turning on both at the same time.
...R
jonawadl
Code: [Select]
should be
Code: [Select]
i.e. one less {
Code: [Select]
else {
...R
Can you explain how to get the direction 'F' ? Please?
Robin2
These seem to be the relevant bits of code
Code: [Select]
   // This is Backward
   // This is Forward
...R
jonawadl
Yes I got that part, but you put an F into the code and it seemed to be recognized as a command it turned blue) why is that? Is it a standard thing that is built in? Or do I need to translate for arduino somehow? I have been reading through a bunch of tutorials and will continue to do so. If you know of one that covers this let me know please.
Jonathan
jonawadl
When I try to compile, it gives me an error at this line:
Code: [Select]
   BluetoothData=Serial.read(joyposVert); //Get Joystick Vertical position from bluetooth
/ta8428k_Relayathan.ino: In function 'void loop()':
ta8428k_Relayathan:64: error: no matching function for call to 'HardwareSerial::read(int&)'
    BluetoothData=Serial.read(joyposVert); //Get Joystick Vertical position from bluetooth.
Right now my code looks like this:
Code: [Select]
int in1 = 10;   //Reverse motor
int in2 = 11;   //Forward Motor
int tx=1;       //Bluetooth TX
int rx=0;       //Bluetooth RX
// Joystick Input
int joyposVert = 50;    //Digital joystick goes from 0-100. 50 is center
  pinMode(in1, OUTPUT);     //Turns revere motor pin into output
  pinMode(in2, OUTPUT);     //Turns forward motor pin into output
  pinMode( tx, OUTPUT);     //TX for Bluetooth
  pinMode(rx, INPUT);       //RX for Bluetooth
  // Motor A
    // This is Backward
else {
    // This is Forward
    analogWrite(in1, MotorSpeed1);  // added for PWM motor controler.
    // This is Stopped
    MotorSpeed1 = 0;
Robin2
#8
Nov 30, 2017, 05:07 pm Last Edit: Nov 30, 2017, 05:08 pm by Robin2
Ignore the colour.
Have you created a variable called "direction"?
What I had in mind was that you would do something like this
Code: [Select]
   // This is Backward
   direction = 'R';
   // This is Forward
   direction = 'F';
...R
jonawadl
Ok I was able to make some progress, I think, but I still have errors that won't go away. It keeps telling me direction was not declared in the scope.
Code: [Select]
  L298N Motor Control Demonstration with Joystick
  L298N-Motor-Control-Demo-Joystick.ino
  Demonstrates use of Joystick control with Arduino and L298N Motor Controller
  // Edited and modified by Jonathan Waldner on Nov.2017 for a relay and a TA8428 Motor driver.
// Motor A
int R = 10;   //Reverse motor
int F = 11;   //Forward Motor
// Joystick Input
void setup(){
  pinMode(R, OUTPUT);     //Turns revere motor pin into output
  pinMode(F, OUTPUT);     //Turns forward motor pin into output
  pinMode(tx, OUTPUT);     //TX for Bluetooth
  // Motor A
  digitalWrite(F, HIGH);
  digitalWrite(R, LOW);
    BluetoothData=Serial.read(); //Get Joystick Vertical position from bluetooth
   // This is Backward
   direction = 'R';
   // This is Forward
   direction = 'F';
    // This is Stopped
    MotorSpeed1 = 0;
The list of errors I have now is here.
/Users/jonathanawaldner/Documents/Arduino/ta8428k_Relayathan/ta8428k_Relayathan.ino: In function 'void loop()':
ta8428k_Relayathan:76: error: 'direction' was not declared in this scope
    direction = 'R';
/Users/jonathanawaldner/Documents/Arduino/ta8428k_Relayathan/ta8428k_Relayathan.ino: At global scope:
ta8428k_Relayathan:79: error: expected unqualified-id before 'else'
ta8428k_Relayathan:89: error: 'joyposVert' does not name a type
ta8428k_Relayathan:90: error: 'joyposVert' does not name a type
ta8428k_Relayathan:92: error: 'MotorSpeed1' does not name a type
ta8428k_Relayathan:97: error: 'MotorSpeed1' does not name a type
ta8428k_Relayathan:99: error: expected declaration before '}' token
exit status 1
jonawadl
That first error. Direction was not declared in this scope confuses me.
How do I declare it? i thought it might be looking for which pin to lift for R and F but that evidently is not it.
Robin2
#11
Dec 01, 2017, 11:29 am Last Edit: Dec 01, 2017, 11:31 am by Robin2
C/C++ requires the type of every variable to be defined before the variable can be used. That's why these lines are at the top of your program
Code: [Select]
You need to add a line
Code: [Select]
char direction;
or
Code: [Select]
char direction = 'F';
if you want to initialize the variable with the value 'F'
You are missing a { at the end of this line
Code: [Select]
to define the group of lines of code that the IF applies to
It would probably be a good idea to have a look at a beginners tutorial on C/C++. Teachers should always be a few pages further on in the text book than the students :)
...R
jonawadl
#12
Dec 01, 2017, 02:41 pm Last Edit: Dec 01, 2017, 03:05 pm by jonawadl
Quote
...R
Oh, I know that all right. That's why I'm doing this now instead of after Christmas when I need to teach it. :).
I have read about designating characters. But the way you present it here leaves me with a question.
If I can say:
Code: [Select]
char direction;
and I can say
Code: [Select]
In the first case I have a direction but no character behind it. Would I not still need to make another statement about 'F' and 'R'. I'll read that section again in the android tutorial. Excuse me for using this space to post my thoughts but I need to air them to give you a chance to correct the errors in my thoughts.
Robin2
#13
Dec 01, 2017, 05:04 pm Last Edit: Dec 01, 2017, 05:10 pm by Robin2
Yes.
But the initial value might be set somewhere else - perhaps after you have checked an input switch. For example you may not know when writing the program whether the motor will be starting in Forward or Reverse.
I don't mean to sound unkind but Christmas is very very close. Starting the course at Easter would give you more chance to get on top of the subject. Expect some of the kids in class to know as much as you about it (even if you defer until Easter) and to pose hard, but sensible questions.
The other challenge you will face is being asked to debug silly mistakes (or not-so-silly mistakes) in the students' programs "Hey mister, it don't work" and that requires a lot of familiarity with programming.
...R
jonawadl
That is fair. What I am teaching will not fall directly after Christmas either way and it will be one small program for a specific purpose. Mostly our focus will be on a specific set of code. Our school will be participating in a small local robot games. Some have expressed interest in going wireless for the sumo challenges. We have one student who programmed a line follower last year so I will be working together with him. It's a small group of about 6-8 students depending on interest level.
So not a full blown course a little workshop to get their bot going. I know that's gonna be challenging enough though. That's why I'm on it.
