Topic: Using an arduino to burn a bootloader onto a atmega168 (Read 1 time) previous topic - next topic
CristobalGordo
I'm following the instructions here http://arduino.cc/en/Tutorial/ArduinoToBreadboard to a tee but I'm getting the following error:
avrdude: stk500_getsync(): not in sync: resp=0x15
I see a lot of people have similar problems with this but I haven't run acrossed any solutions that don't involve a completely different method (like bitbang.)  Does the method in the above tutorial work?  Does this error look familiar?
Barring an easy solution to the above problem....While I ultimately will use this 168 on a breadboard, I do have two arduinos (a duemilanove and an uno) so I think I can burn the bootloader and program it initially using the two arduinos.  However I see that there is a problem using an Uno for this- something to do with the optibootloader and a corresponding solution which I don't understand (optifix.)  Ok so I have a duemilanove and an uno both fuctioning with 328s and bootloaders.  I also have a fresh 168 without a bootloader.  Presumably I want to take out one of the 328s, plug in my fresh 168, and use the other arduino to burn a bootloader.  Is one way easier than the other (i.e. does one way-duemilanove to uno or uno to duemilanove avoid the problems with the optibootloader)?  Big thanks for any help.
Coding Badly
CristobalGordo
no I have not.  I'll look into how to do that.  Try it and see what happens.
CristobalGordo
Wait at what stage do I disable the autoreset?  After I upload the arduinoisp sketch and before I hook up the target chip and burn the bootloader?
CristobalGordo
IT WORKED!  Thanks!  (So far)  I unplugged the arduino, put a 120 ohm resistor between 5v and reset, and burned the bootloader and it seems to have competed the burn without problems.  Now I need to test it out, but I definitely got further than I did before.  Big thanks again.
electrocrook
I was having similar problems but disabling auto reset solved it. I snipped a pin of a DIL socket and put the 328 in that, then the socket in my Duemilanove, worked fine burning the bootloader onto a blank 328. I'll never need to buy a bootloaded chip again - they are much more expensive!
