Pages: 1 [2] 3 4   Go Down
Author Topic: Event-Based Library for Arduino  (Read 7696 times)
São Paulo
Renato
Hello, Terry... It's a bit boring to debug an serial application when the only interface to it is the same serial port. The IDE's Serial Monitor holds an exclusive access to serial port and does not permit things to work toguether. smiley-grin
Send me an email when you feel ready to get back our discussion. OK? smiley-wink
Red Sea, Saudi Arabia
..On The Red Sea
Hi Renato,
Today all my stuff going to Italy for next year from here (Saudi Arabia) is going on the truck.
Couple more days and I can Think. (As we used to say in IBM ...)
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
São Paulo
Renato
From Saudi Arabia to Italy by truck?!  smiley-eek
Miers 46500 France
EmbeddedAT .. From Concept to Prototype to Production
I have just been looking over your event lib. Very nice piece of work, well done. I also programme in .NET SF/CF/MF.
I was wondering if you might like to consider extending the properties lib to use an SD card to overcome the R/W cycle limitations.
I would also be very interested in an event driven ethernet lib and I2C for RFID etc. I am happy to collaborate on these if you fancy taking them on.
Cheers Pete.
Electronics and firmware design and project mentoring
São Paulo
Renato
Bainesbunch, I'm also interested to add more capabilities to the library. My main problem is that I don't have abundant access to electronics components. But feel free to colaborate. New members are realy needed for this project.
Miers 46500 France
OK I think i am going to start work on an XML based Config reader/Writer that uses the SD card through any pins designated for SPI.
I have quite a bit of kit here that if you need to platform any beta code on i'll be happy to run it for you and give feedback.
Have you seen the AikoEvents library for adding time based events, this also looks like it has potential.
Cheers Pete.
Dallas, Texas
I hope you don't mind some constructive criticism. If it were me, I'd go with a looper idiom. This way, the act of looping is completely detached from the logic of each widget's loop. This has some nice advantages in that it allows for the creation of a generalized, powerful, message passing mechanism, possibility of inlinned loop, reduction of code size (important here) helps prevent one widget from causing others to miss critical windows, and is especially useful for timer based events.
A looper implementation would look something like the following pseudo code. Obviously various schemes can be implemented based on your actual requirements and preferred method of dispatch. So don't get too caught up in the specifics.
setup {
  Looper myLooper ;
  Timer myTimer( myLooper ) ;
  MyButton1 myButton1( myLooper ) ;
  MyButton2 myButton2( myLooper ) ;
loop {
  myLooper.loop() ;
Then, rather than have a loop method defined in each looper aware widget, you would define an "execute" or "fire" method which would execute for that iteration through the loop.
Also, I noticed your addTimer method uses realloc. It seems realloc is buggy unless you have the latest avr-libc. It needs to be 1.7.x to avoid the bug from what I read.
Furthermore, your timer-loop implementation runs in linear time. That's bad for anyone who may have a lot of timers; especially when most of then are disabled. In fact, for anyone who may have a lot of timers, the implementation itself may lead to late timer execution/notification. For starters, you might want to look at a linked-list implementation, which would remove the need for a realloc as well as keeping your enabled and disabled timers in two different lists. Of course, ideally, there would not be a linear walk of timers for every loop (especially checking to see which ones are enabled, only to ignore disabled), rather, we would only care about the latest timer, and only ever need to look at the next timer to execute, only ever needing to look at the head of our linked list. That would, of course, require re-evaluation at timer addition rather than every loop interval. Basically forcing timer execution to O(1) [or O(1) + O(n-1) for late timers] and linear time for adding, deleting, and disabling timers.
And speaking of message handling, once you have something like the above, you can now register messages with handlers and/or have the widgets register messages with the looper. Then, when one widget sends a message, the looper can efficiently dispatch the message to another widget's message handler without widget a or b actually knowing about each other.
Aside from that, I love the fact you're trying to standardize on some design patterns. I especially appreciate you're doing this in C++ rather than C.
Miers 46500 France
I was also going to through another wild card into the mix and suggest that rather than actually having a call to the events processor in the main loop we could actually attach one of the timer overflow interrupts to a pump that iterated through the invent processors, it could almost fall into the realms of multi thread then except that we could only run the interrupt thread at the cost of the main loop. so not true multi tasking smiley-sad
When we register an event for testing then we could also specify the frequency of checking. I.E a button need only be tested at 50 hz but the uart or i2c faster so as not to loose data.
Cheers Pete.
Dallas, Texas
That's the kind of thinking I meant when I said:
Basically, if you have an RTC or other interrupt line, you can either set a flag which is checked in the timer's fire method or directly call the execute method from the ISR, depending on the nature of the event and exactly what all needs to be done. Always possible for further divide the ISR into a slow/fast split mechanism.
EDIT: Also want to add that it opens the door for IRQ dispatch via message passing too - again depending on design decisions and goals.
« Last Edit: June 12, 2011, 02:54:15 pm by gerg » Logged
São Paulo
Renato
Bainesbunch, are you thinking about XML parsing using Arduino? I'm not sure if it will be good. XML is good when you want an easy to implement and humam readable way to exchange information, but in my opinion it's realy hard to parse and requires much memory space and processing power. I still prefer to use memory spaces that matches C structs.
gerg, you're right when say that avr memory allocation is buggy, but I also tried the new library version and it's still having a bad behaviour. I've added a method to pre-allocate a memory space to avoid sucessive reallocs, but I was not confident that it would be good and I just not commited it yet to source tree. I think that the Arduino/AVR has many memory issues, what make me avoid the idea of creating a new class to control the common functions like loops because it will spend more stack space and so on. It's a very limited environment when compared to PC programming. Everything needs to be simple as possible.
I liked the suggestion about keeping the next timer to avoid the checking of all array items everytime, I agree that many things may be optimized in this loop (and in the rest of library). I'm only not sure about how much it will improve the precision because if you set tight intervals to hard jobs the timer will never match anyway. And I prefer don't use interrupts because time elapsed measurements are needed for some functions and I also worry about losing serial data.
Be assured that the new versions will bring all your good sugestions. And feel free to submit patches for main source, documentation, examples, etc etc.
« Last Edit: June 12, 2011, 10:05:38 pm by Rferreira » Logged
Miers 46500 France
Not exactly no. I was thinking more on the lines of using XML to store data for configuration and non volatile data from the application in XML on the CF card.
For configuration this would have that advantage of being able to write an XML based configuration for the application to a CF card in an eye readable format that in then converted into its types by the parser when the application loads. so the XML File  might read
<Name="My Variable" Type="INT" Value="100">
<Name="My Variable" Type="STRING" Value="A Sample String">
<Name="My Variable" Type="REA" Value="123.456">
The parser would be able to find the element in the XML file by name and convert the value into its correct type on the Arduino, this would not be wasteful of memory.
To conserve memory further we only read one line of the XML file at a time to process. I think a full XML document reader is to memory hungry four our little toys.
Cheers Pete.
Ireland
Sounds like a job for JSON, rather than XML.
São Paulo
Renato
It's not the same thing, oscarBravo. IMHO, if you can't take advantages of reusability, syntax validation, high level libraries for read/write operations, binary data encoding and so on, XML does not make any sense for me due to it's huge storage and performance overhead. smiley-lol
« Last Edit: June 20, 2011, 12:32:58 pm by Rferreira » Logged
Topsham, Vermont USA
... in The Woods In Vermont
Hi again, Renato,
Sorry for the delay; I have been travelling and now settled back in Vermont USA for the summer.
((I am using a temporary logon/userid because I am locked out of the forum with my regular ID and no one responds to emails  smiley-mad ))
I have been thinking more about issues of "Scheduling", tasks, events etc.  I need to read thru the discussion completely before saying too much.  I have my own viewpoint and "terminology" in mind from my past experience with other RTOS systems like IBM's EDX.  I even read thru the code of the RTOS I wrote long, long ago for the 6502.  So a slow 8-bit micro can definitely do this  smiley
So, more to come...
First pass "Scheduler" ideas: A scheduler simply is another source of "Events" in a system.  The scheduler periodically compares the Real Time Clock with it's list of scheduled events, and if the time has arrived, it posts that event.  I don't think the events posted by a scheduler need to be any different than events posted by other sensor-based or timer-based or counter-based "checkers"..
Maybe...
OK, back soon.  Thanks for your work on this.  Let me know what hardware you would like to test things and I'll get it to you.
Regards, Terry King    terry@terryking.us
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
São Paulo
Renato
Hello, Terry! I have no idea where you really live. smiley-lol
The RTCTimedEvent class is already working here at home and the usage is similar to Unix cron. I will commit it within 2 or 3 days when doc, example, etc, is finally ready.
Thank you for your contribution!
[]s
Renato
« Last Edit: June 28, 2011, 11:46:10 pm by Rferreira » Logged
Pages: 1 [2] 3 4   Go Up
