Topic: Problem with Sanguino, FTDI Cable, Fedora (Read 3388 times) previous topic - next topic
SimeonK
Hello,
I made a Sanguino on breadboard with ftdi cable connection. When i try to upload some sketch, i receive an error:
Code: (a) [Select]
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
My system is
Code: (uname -a) [Select]
Linux MyPC.home 2.6.35.10-74.fc14.x86_64 #1 SMP Thu Dec 23 16:04:50 UTC 2010 x86_64 x86_64 x86_64 GNU/Linux
I have Arduino Duemilanove and it works with my system, without any changes ( naturally i have selected the board from menu ).
On Windows there are no problems - neither with Arduino nor Sanguino.
Here is a list of related packs
Code: (yum list installed rxtx avr-* arduino* avrdude) [Select]
arduino.noarch        0021-2.fc14        @updates
arduino-core.noarch        0021-2.fc14        @updates
arduino-doc.noarch        0021-2.fc14        @updates
avr-binutils.x86_64        2.21-1.fc14        @updates
avr-gcc.x86_64        4.5.1-2.fc14.1        @updates
avr-gcc-c++.x86_64        4.5.1-2.fc14.1        @updates
avr-libc.noarch        1.7.0-1.fc14        @fedora
avrdude.x86_64        5.10-2.fc13        @fedora
rxtx.x86_64        2.2-0.3.20100211.fc14        @updates
Any ideas?
Thanks,
Simeon
madworm
FTDI cable = RTS instead of DTR right ?
Auto reset has never worked for me with that cable on linux. But I haven't tried it for quite a while. There's some info on the playground though.
I suggest getting an ISP programmer and forget worrying about bootloaders.
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
