Topic: [solved] Salvaged LCD (Read 2450 times) previous topic - next topic
Aqlor
Feb 07, 2011, 11:34 pm Last Edit: Feb 08, 2011, 03:20 pm by Aqlor Reason: 1
Hello,
I've never used an LCD before, however I found one today on a pile of electronics I was cleaning up.
It's a 14 pin LCD with no markings so I can't find much help online...
Is there anyway you know of testing this?
Thanks
floresta
How about a photograph of the back?
Don
Aqlor
There you have it
I didn't thought it would be helpful though
bill2009
#3
Feb 08, 2011, 02:47 am Last Edit: Feb 08, 2011, 02:49 am by bill2009 Reason: 1
Raw LCDs are tricky to drive.  Have a look at this http://arduino.cc/forum/index.php/topic,51464.0.html
as a quick experiment try running a 50hz square wave at 3v across the two end pins and see what you get.
floresta
#4
Feb 08, 2011, 03:11 am Last Edit: Feb 08, 2011, 03:16 am by floresta Reason: 1
Quote
At first I thought you were correct, but in that view it looks like the four pins on the right could go to a controller, and the next four may not be connected to anything.  This is consistent with the data pin connections using a 4-bit data interface to an HD44780 controller.  Try following the left pin and see if it goes to ground and see if the third pin from the left goes to the potentiometer.
Don
pwillard
To be honest... from the look of it... it's quite unlikely that is a dot matrix HD44780 driven display.  You should proceed as if it was just a normal, plain glass LCD.
CrossRoads
If nothing else, you've got a lot of nice other parts on that board.
The LCD501 silkscreen is not much help in google.
liudr
Looks like the broken coffee maker I took apart. Only kept a few screws as the display is a bare panel like this one. I wouldn't try it, waste of time.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
CrossRoads
Take a look at this thread, maybe this will  help
Aqlor
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
