Topic: What is this component ? (Read 761 times) previous topic - next topic
tryptophane
Nov 30, 2017, 08:10 pm Last Edit: Nov 30, 2017, 08:52 pm by tryptophane
Hello !
Does anyone know which component is this ? With "GD WOIM" written...
I've found an old electronic board and i can't find it on Google... :smiley-confuse:
Thank you !
raschemmel
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
tryptophane
PaulRB
#3
Nov 30, 2017, 08:57 pm Last Edit: Nov 30, 2017, 09:00 pm by PaulRB
Diode bridge recitifier?
vinceherman
#4
Nov 30, 2017, 09:02 pm Last Edit: Nov 30, 2017, 09:03 pm by vinceherman
I think its a diode bridge rectifier, too.
PaulRB
If we are correct (pretty sure we are) it is basically 4 diodes in a single package, arranged in a diamond shape. It turns AC current into DC current (albeit a very lumpy DC current). Those big caps then smooth this into a more steady DC current.
Southpark
#6
Nov 30, 2017, 09:22 pm Last Edit: Nov 30, 2017, 09:23 pm by Southpark
Just google this:
"W01M"
raschemmel
#7
Nov 30, 2017, 09:44 pm Last Edit: Nov 30, 2017, 09:45 pm by raschemmel
OR,
you could just click here:
(but that would be too easy...)
rogertee
it is called a bridge rectifier has 4 leads ac voltage into sine wave pins you get dc voltage from + - pins
tryptophane
Really thank you for you answers ! Now I know !
MarkT
The legend "BR1" means "bridge recitifier 1".  This is a power supply, there will be a transformer secondary
connected to this board providing the low-voltage AC, and probably some 78XX / 79XX voltage regulators down
the line to provide regulated voltage rails (given the capacitor voltage rating, something like +/-12, 18 or 24V)
(unless this is an unregulated supply).
This power supply design, transformer/bridge rectifier/smoothing cap/linear regulator is not used
in modern equipment, which almost invariably uses switch-mode converters these days which are >10 times
smaller and lighter for a given power level.
I deduce this board is at least 15 years old.
