Topic: Level shifting micro sd breakout doesn't write to file. (Read 648 times) previous topic - next topic
L30N_
Hello everyone,
As you can read in the title, my sparkfun level shifting micro sd breakout doesn't write to files on the SD card. I'm using the following components:
-Arduino pro mini 3.3v ATMega328P
-Sparkfun Level shifting micro sd breakout
-Kingston 16GB micro sdhc cards
The arduino and breakout are hooked up to each other as seen in this fritzing schematic:
The breakout board does make new files, but won't write to them.
Cardinfo give the following serial data:
Code: [Select]
Initializing SD card...Wiring is correct and a card is present.
Card type: SDHC
Volume type is FAT32
Volume size (bytes): 2696937472
Volume size (Kbytes): 2633728
Volume size (Mbytes): 2572
Files found on the card (name, date and size in bytes):
SYSTEM~1/     2017-12-01 17:25:32
  INDEXE~1      2017-12-01 17:25:32 76
TEST.TXT      2000-01-01 01:00:00 0
I wrote a dummy code to demonstrate what happens, as i cannot give you the full code of my boss's project:
Code: [Select]
#include <SD.h>
#include <SPI.h>
File myFile;
const int chipSelect = 8;
  if (!SD.begin(chipSelect)){
    Serial.println("SD.begin failed!");
    return;
if (!SD.open("TEST.TXT", FILE_WRITE)){
    Serial.println("SD file problem!");
    myFile.close();
  else {
    myFile.close();
  if(SD.open("TEST.TXT", FILE_WRITE)){
    myFile.write("Test"); myFile.write("\r\n");
    myFile.write("1, 2, 3"); myFile.write("\r\n");
    myFile.close();
  else{
    Serial.println("SD file problem 2!");
  delay(200);
This code returns "SD file problem 2!", which indicates that writing to the file isn't possible for some reason.
Why does it not write, and how can i solve that?
Thank you all in advance!
L30N_
I solved it myself already, after some more searching on the internet (i had been searching for about 3 hours already) i found that my coding was faulty:
SD.Open() can't be called like it was, but needed to be called as myFile = SD.Open()
