Topic: L298N and problems with steppin motor (Read 2127 times) previous topic - next topic
TomGeorge
#15
Dec 04, 2017, 08:43 am Last Edit: Dec 04, 2017, 08:44 am by TomGeorge
17pm-k502-p2st
Quote
Specifications:
Series: 17PM
Type: Standart
Coil Type: Bipolar
Supply Voltage: 12-36VDC
Steps per Revolution: 200
Step Angle: 1.8°
Diameter - Body: Square 1.65" (42.00mm)
Lenght - Body: 1.299" (33.00mm)
Diameter - Shaft: 0.196" (5.00mm)
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
shimidan
17pm-k502-p2st
Tom.... :)
WOW! I couldn't find these from manufacture sites. Could say what is the current of the motor?
Robin2
#17
Dec 04, 2017, 09:50 am Last Edit: Dec 04, 2017, 09:51 am by Robin2
I got a problem like a4988 stepper..., with my new a4988.
I'm not going to read 3 pages of posts to see what you are talking about. Please just describe exactly what you did (with wiring diagrams) and tell us what your current problem is.
The Pololu a4988 web page has great information about using the A4988.
Read first. Experiment second.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
TomGeorge
I'm trying, unforunate that the info is so limited.
Can you ,measure the resistance of the windings of the stepper?
Thanks.. Tom... :)
shimidan
Thanks.. Tom... :)
Each coil 2.3  Ohm.
shimidan
#20
Dec 04, 2017, 01:25 pm Last Edit: Dec 04, 2017, 01:53 pm by shimidan
...R
Sorry, i couldn't draw it in Proteus.
pins 3 and 4 to step and direction.
5V (arduino uno) to VDD.
right and left GND of uno and GND (next to VDD) to one column of bread board.
V12 of power supply to VMOT.
GND of power supply to GND (next to VMOT).
A 47 micF capacitor  between power supply lines ( N To N, P to P).
Reset and sleep are bridged.
I guess the potentiometer doesn't work correctly (maybe wrong use by me).
Simple code:
  pinMode(3,OUTPUT); // Step
     digitalWrite(3,HIGH); // Output high
    delay(2000); // Wait
    digitalWrite(3,LOW); // Output low
Robin2
Pencil and paper is fine. Then post a photo of the drawing.
It is too easy to misunderstand verbal descriptions of wiring connections.
...R
shimidan
...R
I Think the board is fired! I will buy another. Which screwdriver is proper to adjust this potentiometer?
Robin2
One that fits.
...R
shimidan
#24
Dec 05, 2017, 06:02 am Last Edit: Dec 05, 2017, 06:36 am by shimidan
...R
Robin2
That's a nice drawing and it looks correct. The code in Reply #20 is nearly right. The problem is that you are sending your pulses to the direction pin. And you have no control on the step pin. You need to set the direction pin HIGH or LOW and then send pulses to the step pin.
Try the code in my link in Reply #10. But make sure the pin references are correct for your wiring.
...R
shimidan
...R
Sorry! I've set the wiring times and times. I means that i connected a pin (3 or 4) to step and used 'HIGH' for this pin, but sometimes it was 3 sometimes 4. Thank for your attention.
I think board is down, because i didn't care.
shimidan
A new board and it's working fine. even no needs current adjustment or overheating. Ty all. (Please c http://forum.arduino.cc/index.php?topic=515912.0)
