Loading...
Pages: [1]   Go Down
Author Topic: Wicking - Fast or Clean?  (Read 681 times)
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I'm shopping for solder wick.  The wick is coated with one of two kinds of flux.  The flux provides either the "fastest wicking action" or the "cleanest wick -- clear, non-reactive residues".  I've never used wick so I have no idea which is more important (or if it even matters that much).
I'm going to try my hand at SMD soldering so I'll be using the wick to remove (lots of smiley-grin) solder bridges.  I think "fast" would be best in that case.
Opinions?
Logged
0
Offline Offline
Sr. Member
bluesmokelabs.com
View Profile
WWW
Go with either, I've never noticed a difference.  Plus you will probably end up putting your own flux on it.  Buy a flux pen at the same time, it works wonders!
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Personally, if there is a difference I'd rather go with fast.
Any product that is "no-clean" falls into the same category as hand sanitizer.  Sure it may kill everything, but then you just have a bunch of dead germs on your hands.
In other words, I still clean my boards when I use stuff with "no-clean" flux in it.
Logged
www.cmiyc.com - A guide to being an Enginerd
Georgia, US
Offline Offline
Sr. Member
Arduino makes my head hurt :(
View Profile
I didn't want to know that
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Go with thinner (narrower?) too, heats up faster to melt the solder quicker.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Nowhere
Offline Offline
God Member
View Profile
Definitely use your own flux, though, as said earlier.
I successfully soldered my first SMD board (SF simon) a month ago (new soldering iron for christmas) and had hardly any luck with the wick until applying flux to it.
Logged
Soundcloud page: http://soundcloud.com/beefinator-2
Youtube channel: http://www.youtube.com/user/beefinator14
Old soundcloud page (ran out of minutes): http://soundcloud.com/beefinator
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Thanks!  Just the sort of advice I was hoping to get!
The stuff I'm looking at comes in # sizes: #1, #2, #3, etcetera.  The #1 size is the thinnest / narrowest.  How are your's measured?  Also # sizes?  In millimeters?  Inches?
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Don't know, can't find it at the moment. Is fairly wide tho, not that good for surface mount.
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Found it - MG Chemicals, 0.075", fine braid, static free. Cat # 443
No mention of flux.
Guess its not as wide as I thought it was.
Haven't tried using it with flux added. Usually I use a solder sucker to get most solder off, little cleanup with wick if needed.
« Last Edit: February 08, 2011, 10:38:48 pm by CrossRoads » Logged
0
Offline Offline
Sr. Member
bluesmokelabs.com
View Profile
WWW
The 2.5mm is the ideal size, 1.5 tends to fill up with solder faster than you can move it and 3.5(I think thats next size up) takes too long to heat and you end up burning flux on the board.
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
So what does flux do in a wick? Does flux reduce the melting temperature of solder? I never understood the use of flux.
Logged
0
Offline Offline
Sr. Member
bluesmokelabs.com
View Profile
WWW
It cleans the metal of oxides that occur under heating and allows the solder to flow alot better.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
...in addition, the manufacturer of the "no clean" wick I found claims their flux cleans old flux.  I assume that requires some combination of: chemically altering the old flux, floating the old flux to the solder surface, trapping the old flux.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
I went with PROWICK #4 from TECHSPRAY (fast).  I'll report back after I've used it.
Logged
Pages: [1]   Go Up
Print
Jump to:
