Topic: Could use some help with my 8 switch project...please (Read 1 time) previous topic - next topic
rynd96
Bit of a noob but I've had good luck, until now. I'm working on a setup where you have 8 switches and once they are in the proper position, one led goes off, one led comes on and a relay is triggered. Thought I was on the right track but I'm not having any luck. My guess is that it at the point where the switch conditions are. Any help would be greatly appreciated
  Pin 2 is switch 1
  Pin 3 is switch 2
  Pin 4 is switch 3
  Pin 5 is switch 4
  Pin 6 is switch 5
  Pin 7 is switch 6
  Pin 8 is switch 7
  Pin 9 is switch 8
  Pin 10 is red Led
  Pin 11 is grn Led
  Pin 12 is relay Com
  Pin 13 is n/a
  Pin 2,3,4,5,6,7,8,9 Input
const bool led = 13;
// set pin numbers:
const int interruptPin0 = 2;     // the number of the pushbutton pin 0
const int interruptPin1 = 3;     // the number of the pushbutton pin 1
const int interruptPin2 = 4;     // the number of the pushbutton pin 2
const int interruptPin3 = 5;     // the number of the pushbutton pin 3
const int interruptPin4 = 6;     // the number of the pushbutton pin 5
const int interruptPin5 = 7;     // the number of the pushbutton pin 6
const int interruptPin6 = 8;     // the number of the pushbutton pin 7
const int interruptPin7 = 9;     // the number of the pushbutton pin 8
const int redLedPin =  10;       // the number of the RED LED pin
const int grnLedPin = 11;        // the number of the GRN LED pin
const int relayPin = 12;         // the number of the relay pin
// variables will change:
int buttonState0 = HIGH;         // variable for reading the pushbutton0 status
int buttonState1 = HIGH;         // variable for reading the pushbutton1 status
int buttonState2 = HIGH;         // variable for reading the pushbutton2 status
int buttonState3 = HIGH;         // variable for reading the pushbutton3 status
int buttonState4 = HIGH;         // variable for reading the pushbutton5 status
int buttonState5 = HIGH;         // variable for reading the pushbutton6 status
int buttonState6 = HIGH;         // variable for reading the pushbutton7 status
int buttonState7 = HIGH;         // variable for reading the pushbutton8 status
int puzzle = LOW;                // variable for state puzzle
// the setup funtion runs once when you press reset or power the board
  //initialize digital pin 10, 11, 12 as outputs
  pinMode(redLedPin, OUTPUT);
  pinMode(grnLedPin, OUTPUT);
  pinMode(relayPin, OUTPUT);
  // initialize digital pin 2,3,4,5,6,7,8,9 as inputs with internal pullup resistors
  pinMode(interruptPin0, INPUT_PULLUP);
  pinMode(interruptPin1, INPUT_PULLUP);
  pinMode(interruptPin2, INPUT_PULLUP);
  pinMode(interruptPin3, INPUT_PULLUP);
  pinMode(interruptPin4, INPUT_PULLUP);
  pinMode(interruptPin5, INPUT_PULLUP);
  pinMode(interruptPin6, INPUT_PULLUP);
  pinMode(interruptPin7, INPUT_PULLUP);
  // set the outputs
  digitalWrite(redLedPin, HIGH);  // turn the red LED on
  digitalWrite(grnLedPin, LOW);  // turn the green LED off
  digitalWrite(relayPin, LOW);  // relay off
// the loop funtion runs over and over again forever
  // read the state of the puzzle
  puzzle = (digitalRead(buttonState0 == HIGH) && (buttonState1 == LOW) && (buttonState2 == LOW) && (buttonState3 == LOW) && (buttonState4 == LOW) && (buttonState5 == LOW) && (buttonState6 == LOW) && (buttonState7 == LOW));
  // check if the puzzle is solved
  // if it is, the puzzle state is low or zero volts
   if (puzzle == LOW) {
    // delay to avoid randomly flicking switches
    delay (1500);
      // turn red led off, grn led on and trigger relay
      digitalWrite(redLedPin, LOW);  // turn the red LED off
      digitalWrite(grnLedPin, HIGH);  // turn the green LED on
      digitalWrite(relayPin, HIGH);  // relay on
      // wait time for reset
      delay (10000);
   else { // else reset the puzzle
    // turn redLed on and relay off
ieee488
I am not sure I understand you want the circuit and this program to do.
rynd96
It's a box with 8 eight toggle switches, put all eight switches in the correct position and a relay triggers a solenoid which allows you to open a box with a gift inside. It's for my son for Christmas, he loves puzzles so I thought I'd be able to pull it off but I've hit a road block
larryd
You need to do digitalRead on all 8 input pins.
Quote
You need:
if(digitalRead(interruptPin0) == HIGH  && digitalRead(interruptPin1) == LOW && digitalRead(interruptPin2) == LOW . . .
No technical PMs.
The last thing you did is where you should start looking.
rynd96
Thanks for the help. I got the switch combination working properly so that's awesome.
I am having an issue with the "delay" though.
What I was hoping for was once the switches are in the right order, the program reads that, delays for 1.5 seconds, reads it again and triggers the "win" state. This would circumvent my son just randomly flipping switches to get the box open.
However once all the switches are in the proper position, it's taking anywhere from 2 to 12 seconds for the program to go into the "win" state. I've timed it multiple times and it's all over the place.
Any idea what could be causing this?
larryd
When you make changes to the code, we need to see them.
Always show us your 'current' compete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
Also:
Show us a good schematic of your circuit.
Show us a good image of your wiring.
No technical PMs.
rynd96
Here's the current working code, save for the delay issue. Neither one of the delays seem to be working correctly. I have one delay near the beginning of the "if" statement to avoid solving the puzzle with random switch flicking prior to the win state and one later for the reset.
Haven't had time to do the diagram just yet as I wanted to see if it would work first but I will post it later today
Code: [Select]
  Pin 2 is switch 1
  Pin 3 is switch 2
  Pin 4 is switch 3
  Pin 5 is switch 4
  Pin 6 is switch 5
  Pin 7 is switch 6
  Pin 8 is switch 7
  Pin 9 is switch 8
  Pin 10 is red Led
  Pin 11 is grn Led
  Pin 12 is relay Com
  Pin 13 is n/a
// set pin numbers:
  // set the outputs
  digitalWrite(relayPin, HIGH);  // relay on for NO
  puzzle = (digitalRead(interruptPin0) == HIGH  && digitalRead(interruptPin1) == LOW && digitalRead(interruptPin2) == HIGH && digitalRead(interruptPin3) == LOW  && digitalRead(interruptPin4) == HIGH && digitalRead(interruptPin5) == LOW && digitalRead(interruptPin6) == LOW  && digitalRead(interruptPin7) == LOW);
    delay (1500);
      digitalWrite(relayPin, HIGH);  // turns relay off for NC
      delay (10000);
    // turn redLed on and relay on
    digitalWrite(relayPin, LOW);  // relay on
PaulRB
I can't explain your random delay issue, but I spotted this:
Code: [Select]
    delay (1500);
If "puzzle" has the value LOW before the delay(1500), it will still be low after the delay. I think you need to re-evaluate "puzzle" after the delay to see if all switches are still in the correct position.
larryd
It's not fair to have to guess 0-255 to open a gift  :'(
No technical PMs.
rynd96
Code: [Select]
    delay (1500);
My thought was, the delay of 1.5 seconds should prevent anyone from randomly guessing the correct switch position by just flicking switches on and off. Then it reads the state again and if still LOW, triggers the "win" state. Am I off base?
rynd96
Forgive my noob-ness but I don't know what your referring to Larry?
PaulRB
Am I off base?
Yes. I understand your idea, but that's not what your code is doing. Just look at the lines I highlighted. They get executed one immediately after the other. Every time. Nothing happens in-between those lines.
larryd
Quote
It's a box with 8 eight toggle switches, put all eight switches in the correct position and a relay triggers a solenoid which allows you to open a box with a gift inside. It's for my son . . .
With 8 switches he has a possibility of 256 different combinations to try before he gets his reward. ;)
No technical PMs.
rynd96
Lol, I was going to make up a puzzle for that but...
