Topic: Driving 12v SevSeg from Arduino 5v (Read 966 times) previous topic - next topic
islarky88
hi guys, i'm having problems with driving the 12v SevSeg (10pin sevseg. 3pin for digit[cathode] 7pin for segments[anode]
I'm currently using this library https://github.com/DeanIsMe/SevSeg
and was able to do it small scale
both are common cathode and i'm having problem with driving the 12v SevSeg
1. do i need some kind of drivers for this?
2. can i just use a NPN transistor on the segment pins and PNP on the digit pins
Grumpy_Mike
1) yes, without you will damage your Arduino.
2) It top switching 12v you need both. If bottom switching you need just an NPN. For example if you have a common anode just connect it to 12 V with the cathode connected to the resistor and then to the collector, emitter to ground and base through a resistor to Arduino output.
islarky88
Thank you kind sir.. can you guide me to a driver so i can do my research and test on it.. I'm kinda new to electronics... thank you so much
Grumpy_Mike
Only if you can tell me what sort of seven segment display you have? Is it common cathode or common anode?
islarky88
@Grumpy_Mike
It's a 12v sevseg common cathode.. i tested by directly connecting the segment pins to positive and a digit pin to negative.
Grumpy_Mike
#5
Dec 05, 2017, 02:21 pm Last Edit: Dec 05, 2017, 02:55 pm by Grumpy_Mike
Quote
Don't do that you will damage your digital pin as it puts 12 V on it when it is off which is way over the Vcc + 0.5V limit.
Quote
That is probably the worst way round. You need an NPN and PNP to drive each segment.
islarky88
i hooked it to a 12v power supply. hehe. thanks for this mike... i learned something new today.
and out of curiosity, how should i connect things with a common anode 12v sevseg?
Grumpy_Mike
Quote
The same almost. The single NPN pulls down the segments and the segment driver circuit is connected to the common anode.
