Topic: Possible Solution in Controlling Multiple Relays (Read 680 times) previous topic - next topic
EXIA_00
Hi everyone I have a problem in choosing what kind of IC that is possible to expand the pins in Arduino to control multiple relays and my possible option to expand the pins in arduino for the relay that I am thinking is:
- MCP23017
- 74HC595
- 74HC4067
- 74HC4051
Wawa
Hard to give advice without knowing more about your relays.
Have a look at the TPIC6B595 (ebay).
Shift register, exactly like the 74HC595, but with eight 150mA open drain outputs.
Leo..
Edit:
I see that you have already been told here by PaulRB
https://forum.arduino.cc/index.php?topic=514726.0
So why ask again in a new thread.
Alzheimer's?
EXIA_00
Is it possible to control the TPIC6B595 in any arduino pin?
PaulRB
EXIA_00
Edit:
Alzheimer's?
Because I still don't have any experience in using 595, while in 4051 I have use it before as a demux  but I still haven't tried it in relay
Wawa
Because I still don't have any experience in using 595...
Then ask if you don't understand.
Starting a new thread for the same problem isn't going to help.
This page might get you started.
Don't use the 1uF capacitor from the latch pin to ground.
That is a long standing error on this page that nobody seems to be able to correct.
Us a 100n decoupling cap from VCC of the chip to ground if you have one.
Once you understand how to control the LEDs, you can move on to controlling relays.
The only difference is that a TPIC chip is sink only, so the load (LED or relay) goes between output and VCC, not between output and ground.
Relay supply for a TPIC can be a higher voltage, e.g. 12volt for 12volt relays.
Add a diode across the relay coil to kill back-emf.
Leo..
