Topic: Connection and sending e-mail with Arduino Uno WiFi (Read 4439 times) previous topic - next topic
Michele94
Hello everyone,
I am a beginner on the subject and I am making a project with Arduino UNO WiFi (https://store.arduino.cc/arduino-uno-wifi) which consists of alerting the user by e-mail if certain thresholds of gas (detected with appropriate sensors) were exceeded.
I set the Arduino UNO WiFi through the following guide:
https://www.arduino.cc/en/Guide/ArduinoUnoWiFi
I'm having problems in the code related to the connection  to the internet with the consequent creation and sending of the e-mail. After several searches on the internet, I did not find anything that referred to the Arduino UNO WiFi but only codes related to Arduino UNO + shield Ethernet / WiFi.
I tried to follow the guide found on this forum at the following address:
http://playground.arduino.cc/Italiano/Mail
trying to adapt the instructions of the Ethernet library with those of the WiFi library without success.
The arduino UNO WiFi can be treated as an arduino UNO + shield wifi or needs specific libraries? Is the WiFi.h library sufficient?
If someone can give me a hand I would be really grateful.
Thank you.
Michele
Juraj
Michele94
So it is obligatory to change firmware or it'possible to use <UnoWiFiDevEd.h>  to permit Arduino to connect and send emai?
in the case in which we must install a new firmware, we have to install Expressif AT firmware or Wifi link firmware?
For the connection of Arduino we tried to use <UnoWiFiDevEd.h> ,but we have in output on the serial monitor value=0 therefor false,where is the error?
#include <UnoWiFiDevEd.h>
char ssid[]="X";
char pass[]="X";
int time=1000;
int wait=1000;
ArduinoWifiClass *wd=new ArduinoWifiClass();
  Serial.println("Program started,waiting for router...");
  delay(time);
  Serial.println("Starting network module...");
wd->begin();
wd->connect(ssid,pass);
delay(2000);
Serial.println("Connecting...");
boolean value= wd->connected();
Serial.println(value);
Juraj
you can't send email with factory firmware. I recomend WiFi Link
Michele94
Excuse me Juraj, I have a couple of questions:
1. The library that you linked to me can only be used by changing the Arduino UNO wifi firmware, right? What does the firmware change mean from an electronic point of view (using pins, etc.)?
2. I read this on the link you sent me: "UNO WiFi Developer Edition connects ATmega328 to ESP8266 using additional on board UART chip SC16IS750. This additional UART is connected to ATmega as I2C device." Being ignorant on the subject, what does it mean? Is the SC16IS750 chip already on the Arduino UNO Wifi?
I hope you can help me, I'm in a panic.
Thanks so much.
Michele
Juraj
no problem. I am on 'the mission' for perfect Uno WiFi for everyone :-)
the Uno WiFi Serial1 library is independent from firmware. it only makes the connection to the esp8266 WiFi chip.
WiFi Link library requiers WiFi Link firmware
no change
yes, it is what makes Uno WiFi unique for now
WiFi Link is for general networking. it is easy to port sketches written for Ethernet or WiFi library.
every day there are more Uno WiFi owners with Uno WiFi with Serial 1 and WiFi Link. the community grows.
Michele94
Thank you very much :), later I change the firmware and then I will try to sketch the code for the connection of the Arduino to the internet with the relative sending of e-mail.
If I had problems with the code, could you still give me a hand?
Thank you again!
Juraj
yes
yes
and write immediately if something doesn't work in WiFi Link installation sequence
Michele94
Hi juraj, I followed the guide you suggested to me: https://github.com/jandrassy/UnoWiFiDevEdSerial1.
I have carried out all the various steps indicated and at the moment I am following the following guide: https: //github.com/jandrassy/arduino-firmware-wifilink.
I'm stuck for a few hours in the passage: "Go to config.h tab and uncomment the #define for your board or GENERIC_ESP8266". To which define do I have to remove the comment?
This is the config.h code:
Code: [Select]
 * Firmware version and build date
#define BUILD_DATE  __DATE__ " " __TIME__
#define FW_VERSION  "1.1.0"
#define FW_NAME     "wifilink"
 * Define board model name
//#define STAROTTO
//#define PRIMO
//#define UNOWIFIDEVED
//#define UNOWIFI
//#define GENERIC_ESP8266
//#define MCU_OTA
 * Enable/Disable Debug
//#define DEBUG
//#define BAUDRATE_DEBUG 115200
 * Define board hostname
#define DEF_HOSTNAME "arduino"
 * Defines the communication channel between microcontroller
 * and esp82266, with concerning parameters
//#define HOSTNAME "arduino" //used by mdns protocol
#if defined(STAROTTO)
  //Arduino STAR OTTO configuration parameters
  #define BOARDMODEL "STAROTTO"
  #define ARDUINO_BOARD "star_otto" //mdns
  #define ESP_CH_UART
  #define BAUDRATE_COMMUNICATION 460800
  #define WIFI_LED 14
  #define SSIDNAME "Arduino-Star-Otto"
#elif defined(PRIMO)
  //Arduino PRIMO configuration parameters
  #define BOARDMODEL "PRIMO"
  #define ARDUINO_BOARD "primo"     //mdns
  #define ESP_CH_SPI
  #define WIFI_LED 2
  #define SSIDNAME "Arduino-Primo"
#elif defined(UNOWIFI)
  //Arduino UNOWIFI configuration parameters
  #define BOARDMODEL "UNOWIFI"
  #define ARDUINO_BOARD "unowifi"     //mdns
  #define ESP_CH_SPI
  #define WIFI_LED 2
  #define SSIDNAME "Arduino-Uno-WiFi"
#elif defined(UNOWIFIDEVED)
  //Arduino UNO WIFI DEV. EDITION configuration parameters
  #define BOARDMODEL "UNOWIFIDEVED"
  #define ESP_CH_UART
  #define BAUDRATE_COMMUNICATION 115200 // assuming use of Serial1
  #define WIFI_LED 14
#elif defined(GENERIC_ESP8266)
  #define BOARDMODEL "GENERIC_ESP8266"
  #define ARDUINO_BOARD "esp8266"   //mdns
  #define ESP_CH_UART
  #define BAUDRATE_COMMUNICATION 9600 // to start with SoftwareSerial, set 115200 for good connection
  #define WIFI_LED 14
  #define SSIDNAME "ESP8266-Module"
#endif
Thank you so much!
Juraj
Michele94
OK, thank you. After performing the next step: "In the tools menu select board options and choose your board / shield / module or Generic ESP8266 from the ESP8266 section of the board menu.", I encounter the following error during verification:
Code: [Select]
In file included from C: \ Users \ Apollonia \ Documents \ Arduino \ ArduinoFirmwareEsp \ ArduinoFirmwareEsp.ino: 6: 0:
sketch \ Configuration.h: 26: 25: fatal error: ArduinoJson.h: No such file or directory
  #include <ArduinoJson.h>
compilation terminated.
exit status 1
Error compiling for board Arduino.
Where did I go wrong?  :smiley-confuse:
Juraj
Michele94
I installed the ArduinoJson library, the file is compiled and I display the following lines:
Code: [Select]
Archiving built core (caching) in: C:\Users\APOLLO~1\AppData\Local\Temp\arduino_cache_484843\core\core_esp8266_esp8266_arduino-esp8266_BoardModel_unowifideved,UploadSpeed_115200,FlashSize_4M1M_871cf574c062a3909371a8db80bd9ca3.a
Sketch uses 345579 bytes (33%) of program storage space. Maximum is 1044464 bytes.
Global variables use 43320 bytes (52%) of dynamic memory, leaving 38600 bytes for local variables. Maximum is 81920 bytes.
Is it correct?
However, I forgot to perform the following step: "install the Arduino ESP8266 filesystem uploader IDE plugin". Is it necessary to do it? Because I read that the procedure was tested for the version of the Arduino IDE 1.6.5-r2, 1.6.6 and at the moment I use version 1.8.5.
Thanks so much.
Juraj
yes the spiffs uploader is necessary
the build is ok
Michele94
Hi Juraj,
I'm having problems with the file system upload guide.
https://github.com/esp8266/arduino-esp8266fs-plugin/blob/master/README.md
I followed everything step by step, but when I click on "ESP8266 Sketch Data Upload" a window will pop up saying:
"No files have been found in your data folder! Are you sure you want to create an empty SPIFFS image?"
In the previous steps it does not tell me to load something in the data folder, it says:
"Create a directory named data and any files you want in the file system there."
What do you advise me to do?
Thank you very much
Ps. I do not think it can be a problem of incompatibility with the version of the IDE
