Topic: ESP32/ESP8266 connect to localhost server using WiFi (Read 5974 times) previous topic - next topic
eahabissac
Dec 05, 2017, 06:48 pm Last Edit: Dec 05, 2017, 08:50 pm by eahabissac
Hi, I have made a simple local server to receive the data from ESP and put it in data base
the server is working fine as I tested it using postman. the server is listening to port 127.0.0.1:3000
my problem is that client.connect(host,port) returns false.
Code: [Select]
#include "Arduino.h"
#include "WiFi.h"
WiFiClient client;
const IPAddress server(192,168,1,10);
const int httpPort = 3000;
const char* ssid = "******";
const char* password =  "********";
  Serial.println("Booted");
  Serial.println("Connecting to Wi-Fi");
  WiFi.begin (ssid, password);
  WiFi.mode(WIFI_STA);
    Serial.print(".");
    yield();
  Serial.println("WiFi connected");
 if (client.connect(server,httpPort )){
 Serial.println("Client Connected");
 else{
     Serial.println("No Connection");
// The loop function is called in an endless loop
//Add your repeated code here
Juraj
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
Juraj
use
Code: [Select]
#include <ESP8266WiFi.h>
and remove those arduino includes
eahabissac
use
Code: [Select]
This is ESP32 WiFi library not Arduino WiFi library
I have removed the doubled "Arduino.h"  the problem is not there
Juraj
eahabissac
from esp8266 arduino core 2.3?
I have tested the provided example on ESP32 and ESP8266 on both platforms the connection to the localhost failed
for sure when I am switching the platforms for testing I change the WiFi library
WiFi.h for ESP32
ESP8266WiFi.h for ESP8266
I am using esp8266 core 2.2.0 and the latest  for ESP32 core
Juraj
ok. I understand.
the examples work? WiFiClient example?
eahabissac
ok. I understand.
Yes I can connect to any online host like "script.google.com" or sparkfun
Juraj
the IP address is correct? in post text you have the loopback address and in sketch a real address.
eahabissac
IPv4 Address. . . . . . . . . . . : 192.168.1.10
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
I was disparate so I reset it manually :D yes its correct
Juraj
it is the server address, right? not the esp address?
the server is http or https?
eahabissac
yes, my pc IP address which runs the local  server
Juraj
the postman url, if you test it from browser is http or https? why port 3000? it is unusual
eahabissac
its http
3000 No reason,
its working fine with postman
