Topic: Compile error  (Read 1 time) previous topic - next topic
Voel
Hi, My name is Leo and I am new to this forum and new to arduino too.
I get a compile error when trying to upload the attached file to an Arduino Mega. Below you see the error message
Hope somebody can help me out.
Thank you in advance.
Error message:
Arduino: 1.8.4 (Windows 10), Board:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FLiGH  HiGH\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10804 -build-path C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_build_252979 -warnings=all -build-cache C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_cache_599458 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\FLiGH  HiGH\Documents\Arduino737-master\Arduino737\Arduino737.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FLiGH  HiGH\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10804 -build-path C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_build_252979 -warnings=all -build-cache C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_cache_599458 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\FLiGH  HiGH\Documents\Arduino737-master\Arduino737\Arduino737.ino
Using board 'mega' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
WAARSCHUWING: Categorie '' in bibliotheek EEPROM is niet geldig. Wordt gewijzigd naar 'Uncategorized'
Build-opties gewijzigd, alles wordt opnieuw gebuild
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_build_252979\sketch\Arduino737.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\FLiGH  HiGH\Documents\Arduino\libraries\LedControl-1.0.6\src" "C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_build_252979\sketch\Arduino737.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Users\FLiGH  HiGH\Documents\Arduino\libraries\LedControl-1.0.6\src" "C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_build_252979\sketch\Arduino737.ino.cpp" -o "C:\Users\FLIGHH~1\AppData\Local\Temp\arduino_build_252979\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\FLiGH  HiGH\Documents\Arduino737-master\Arduino737\Arduino737.ino:3:24: fatal error: LedControl.h: No such file or directory
#include <LedControl.h>
compilation terminated.
Bibliotheek LedControl-1.0.6 op versie 1.0.6 in map: C:\Users\FLiGH  HiGH\Documents\Arduino\libraries\LedControl-1.0.6  wordt gebruikt
exit status 1
Fout bij het compileren voor board Arduino/Genuino Mega or Mega 2560
Delta_G
#1
Dec 06, 2017, 01:04 am Last Edit: Dec 06, 2017, 01:04 am by Delta_G
It doesn't get much clearer than that.  Have you installed that library?  How and where?
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Voel
Thank you for replying. The library is installed in C:\Users\FLiGH  HiGH\Documents\Arduino\libraries
The installation of the library went via the menu: add .zip library
Delta_G
#3
Dec 06, 2017, 01:21 am Last Edit: Dec 06, 2017, 01:21 am by Delta_G
OK, when you look at that folder what's in it?  What filenames?  The folder doesn't have "Master" added to the end of the name does it?
|| | ||| | || | ||  ~Woodstock
Voel
There are all folders in this folder:
EEPROM
Encoder-1.4.1
Ethernet-1.1.2
LedControl
readme.txt
There is no ""Master"" added to the folder
Delta_G
What's inside LedControl is what I was getting at.
|| | ||| | || | ||  ~Woodstock
Voel
Inside LedControl:
Folder - examples
Folder - src
kewords.txt
library.properties
LICENSE
Delta_G
#7
Dec 06, 2017, 01:39 am Last Edit: Dec 06, 2017, 01:39 am by Delta_G
What's inside src?
We're looking for LedControl.h and LedControl.cpp  in case you find it somewhere else.
|| | ||| | || | ||  ~Woodstock
Voel
Both files LedControl.cpp and LedControl.h are in the src folder
Delta_G
cut them from that folder and paste them one level up in that LedControl folder.  See if it compiles now.
|| | ||| | || | ||  ~Woodstock
pert
LedControl
The IDE output you posted contradicts you:
That translates to
Code: [Select]
Using library LedControl-1.0.6 at version 1.0.6 in folder: C:\Users\FLiGH  HiGH\Documents\Arduino\libraries\LedControl-1.0.6
This is strange that it says the library was used but also that it can't find LedControl.h.
Voel
I have fixed it! Thank you very much for your help. I have copied the library files to:
Deleted the files in folder  C:\Users\FLiGH  HiGH\Documents\Arduino\libraries
That did the job.
Thanks for your help
pert
It's a bad idea to install libraries to C:\Program Files (x86)\Arduino because they will all be lost whenever you update to a different version of the Arduino IDE, then you'll be trying to figure out why none of your projects will compile with the new IDE version.
Voel
Oke, that is not good indeed, but what is the best place to put the files in?
pert
Always install libraries to the libraries subfolder of your sketchbook folder. You can find/set the location of the sketchbook folder in the Arduino IDE at File > Preferences > Sketchbook location.
