Topic: Controlling NEMA 34 motor, for audio indexing system  (Read 1 time) previous topic - next topic
flytyer232
Hello,
I am still working on an audio indexing system, for a punching machine that i am making for school. i am using AccelStepper to ramp up/down the stepper motor. I have done alot of work with AccelStepper, in getting this bit of code to move the motor forward and back
Code: [Select]
int moveMobileCylinderForward( float distanceInInches )
  long stepsToMove = distanceInInches*stepsPerInch;
  long deccel_step = stepsToMove-1000;
  //move forward
   stepper.moveTo(stepsToMove);
   while (stepper.currentPosition() != deccel_step) // Full speed up to 300
     stepper.run();
   stepper.stop(); // Stop as fast as possible: sets new target
   stepper.runToPosition();
  // Now stopped after quickstop
int moveMobileCylinderBackward( float distanceInInches )
  //move forward
   stepper.moveTo(-stepsToMove); // negative because moving backwards
   while (stepper.currentPosition() != 0) // Full speed back to 0
     stepper.run();
Next, in order for the operator to interface with the system, and the system to move the motor back and forth discrete distances, i need to come up with an interface/control system. I decided to use Sanwa buttons, as they have been used quite a bit, and was able to figure that bit of code out. The problem being, when I incorporate the two bits of code, the control system works, however the Arduino isn't giving a the required output signal for the motor. The code is below. Any help would be very, very much appreciated.
flytyer232
Here is the full code, forgot to put on post:
Code: [Select]
// "Select" button allows user to select which profile to punch.
// "Start" button starts punching the profile (or pauses the machine if it is already punching).
// "Reset" button lets user tell machine that the workpiece has been removed.
#include "AccelStepper.h"  //use "" and no <>, b/c accelstepper is a librabry that i defined
class pneumaticClamp
  int myPin;
  // Constructor
  public:
  pneumaticClamp( int pin )
  myPin = pin;
  void clamp()
    digitalWrite( myPin, HIGH );
  void unClamp()
    digitalWrite( myPin, LOW );
class punch
  int myPin;
  // Constructor
  public:
  punch( int pin )
  myPin = pin;
  void punchHole()
    delay( 1000 ); // Give it time to punch through the material
//board stuff
const int serialBaudRate = 9600; // [bps]
const int oneTimeStep = 33;  // Smallest timestep in milliseconds
//pin assignments
const int selectButtonPin = 2; // Number of pin connected to "select" button
const int startButtonPin = 3; // Number of pin connected to "start" button
const int resetButtonPin = 4; // Number of pin connected to "start" button
const int mechStopPins[] = { 10, 11, 12, 13 };
const int mobileClampPin = 8;
const int staticClampPin = 9;
const int alertPin = 6;
const int punchPin = 7;
//constants for motor movement
float stepsPerInch = 2272.727;
//profile checking
bool punchingAProfile  = false;
bool workpieceNeedsToBeRemoved = false;
bool selectIsDown      = false;
bool selectWasDown     = false;
bool selectFreshlyUp   = false;
bool startIsDown       = false;
bool startWasDown      = false;
bool startFreshlyUp    = false;
bool resetIsDown       = false;
bool resetWasDown      = false;
bool resetFreshlyUp    = false;
const int numDistancesPerProfile = 21;
//hole patterns, in inches
float distanceBetweenConsecutiveHoles[ 4 ][ numDistancesPerProfile ] = {
        { 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 0, 0, 0,0 },  //IS-8-bottom rail
        { 4.000, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 5.333, 0, 0, 0, 0, 0, 0, 0,0 },                  //IS-6-bottom rail
        { 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364}, //IL-8-botoom rail
        { 3.273, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 4.364, 0, 0, 0, 0, 0}       //IL-6-bottom rail
        }; // a list of the intervals between consecutive holes for each profile.  If 0, that means there is no next hole.
int chosenProfile = 0; // 0: 6S, 1: 6L, 2: 8S, 3: 8L
pneumaticClamp mobileClamp( mobileClampPin );
pneumaticClamp staticClamp( staticClampPin );
punch unicyl( punchPin );
//stepper motor intilization, for accel stepper
AccelStepper stepper(1,0,1); //pin 9 =pluse, pin 8=direction
  pinMode( mechStopPins[0], OUTPUT );
  pinMode( mechStopPins[1], OUTPUT );
  pinMode( mechStopPins[2], OUTPUT );
  pinMode( mechStopPins[3], OUTPUT );
  pinMode( mobileClampPin, OUTPUT );
  pinMode( punchPin, OUTPUT);
  pinMode( staticClampPin, OUTPUT );
  pinMode( alertPin, OUTPUT );
  pinMode( selectButtonPin, INPUT );
  pinMode( startButtonPin,  INPUT );
  pinMode( resetButtonPin,  INPUT );
  Serial.begin( serialBaudRate );
  //for stepper motor control
  stepper.setMaxSpeed(2000);    //in steps per second
  stepper.setAcceleration(1400); //in steps per second
  selectIsDown = digitalRead( selectButtonPin );
  startIsDown  = digitalRead( startButtonPin  );
  resetIsDown  = digitalRead( resetButtonPin  );
  if ( selectWasDown && !selectIsDown ){ selectFreshlyUp = true; }
  if ( startWasDown  && !startIsDown  ){ startFreshlyUp  = true; }
  if ( resetWasDown  && !resetIsDown  ){ resetFreshlyUp  = true; }
  digitalWrite( mechStopPins[0], LOW );
  digitalWrite( mechStopPins[1], LOW );
  digitalWrite( mechStopPins[2], LOW );
  digitalWrite( mechStopPins[3], LOW );
  if ( punchingAProfile ){
    // if punching a profile
    punchProfile();
    workpieceNeedsToBeRemoved = true;
    digitalWrite( alertPin, HIGH );
    // if not punching a profile
    if ( workpieceNeedsToBeRemoved )
      //see if reset button was freshly pressed and if so, set this variable to false.
      if ( resetFreshlyUp ){
        digitalWrite( alertPin, LOW );
      if ( selectFreshlyUp ){
        if ( chosenProfile == 3 ){
         chosenProfile = 0;
        else{ chosenProfile++;
      if ( startFreshlyUp ){
        // Switch into "punching a profile" mode
        punchingAProfile = true;
      digitalWrite( mechStopPins[ chosenProfile ], HIGH );
  selectWasDown = selectIsDown;
  startWasDown  = startIsDown;
  resetWasDown  = resetIsDown;
  delay( oneTimeStep );
void punchProfile()
  mobileClamp.clamp();
  staticClamp.clamp();
  delay( 2000 ); // Give clamps time to clamp securely
  unicyl.punchHole();
  for (int i=0; i < numDistancesPerProfile; i++){
    int distanceToMove = distanceBetweenConsecutiveHoles[ chosenProfile ][ i ];
    if ( distanceToMove != 0 )
      moveWorkpieceForward( distanceToMove );
      unicyl.punchHole();
  mobileClamp.unClamp();
  staticClamp.unClamp();
void moveWorkpieceForward( int distanceToMove )
  //Serial.print( "Moving workpiece " );
  //Serial.print( distanceToMove );
  Serial.print( "mClamp -> " );
  moveMobileCylinderForward(distanceToMove); //moving forward
  Serial.print( ". " );
  delay( 1000*distanceToMove ); // REMOVE
  Serial.print( "mClamp <- " );
  moveMobileCylinderBackward(distanceToMove );  //moving backward
  delay( 1000*distanceToMove ); //REMOVE
  delay(2000); //REMOVE
  //move forward
     stepper.run();
  //move forward
     stepper.run();
Robin2
You can't use delay() in a program that uses accelstepper. And your calls to stepper.run() should be in loop(), not inside a function. They need to be called all the time and as often as possible - hundreds or thousands of times per second..
Have a look at how millis() is used to manage timing without blocking in Several things at a time.
Have a look at Using millis() for timing. A beginners guide if you need more explanation.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
flytyer232
On the first part, i took the delays out, and found a couple errors that i have since took out, and it works! The table moves forward and back, according to the profile, as seen in the code.
I am still really struggling to grasp what you are recommending to do with the millis(). According to the examples, i can pretty much use it like a delay? What would the structure of that look like?
Code: [Select]
  int myPin;
  // Constructor
  public:
  myPin = pin;
  void clamp()
  void unClamp()
class punch
  int myPin;
  // Constructor
  public:
  punch( int pin )
  myPin = pin;
  void punchHole()
//board stuff
//pin assignments
const int selectButtonPin = 4; // Number of pin connected to "select" button
const int startButtonPin = 5; // Number of pin connected to "start" button
const int resetButtonPin = 6; // Number of pin connected to "start" button
const int alertPin = 0;
//profile checking
AccelStepper stepper(1,3,2); //pin 3 =pluse, pin 2=direction
    punchProfile();
         chosenProfile = 0;
void punchProfile()
  unicyl.punchHole();
      unicyl.punchHole();
  int xa=0;
  int xb=0;
  xa = moveMobileCylinderForward(distanceToMove); //moving forward
 // delay( 1000*distanceToMove ); // REMOVE
  xb = moveMobileCylinderBackward(distanceToMove );  //moving backward
  //delay( 1000*distanceToMove ); //REMOVE
  //delay(2000); //REMOVE
  //move forward
     stepper.run();
  long stepsToMove = -1*distanceInInches*stepsPerInch; //want to make this negative, so
  //move forward
   stepper.moveTo(stepsToMove); // has to be negative because moving backwards
     stepper.run();
flytyer232
Also,
I do have stepper.run in a loop, a while loop to be exact, which is within the function. It seams to work, but how would i put this in a different loop, as you recommend?
Code: [Select]
  int xa=0;
  int xb=0;
  //move forward
     stepper.run();
  //move forward
     stepper.run();
jremington
#5
Dec 06, 2017, 07:49 pm Last Edit: Dec 06, 2017, 07:55 pm by jremington
Quote
Study the simple "blink without delay" example that comes with the Arduino software package.
The following code is blocking and is a bad idea. Nothing else can run until it finishes. You need to learn new program strategies (exemplified by "blink without delay" and more sophisticated examples like "how to do several things at the same time") for controlling a process.
Code: [Select]
     stepper.run();
Robin2
Also,
I did not mean any old different loop. I mean in the function that is called loop(). Something as simple as
Code: [Select]
  // all your other code
  myStepper.run()
Quote
You can use millis() to obtain a similar effect to a delay() but the way it is done is different. The structure is in my examples.
Using millis() is much the same as using your kitchen wall clock to time the cooking of a chicken. Using delay() is the equivalent of sitting watching the oven for 90 minutes - which you would not dream of doing. Instead you note the time when the chicken goes in the oven and periodically check the clock to see if the 90 minutes has elapsed.
...R
flytyer232
Okay, guys, i spent quite a bit of time trying to understand and use millis(). I did implement a version of that code, however ran into some issues. Looking back, these issue persisted in the code without using millis() as well.
Basically, the stepper motor is going forward and back, but is coming back further than it is going forward.and the weird thing is this only happens for the first hole of the profile? i.e. the second profile return to the same point, as with the remaining 20 profiles.
I took all my "control" code out, hooked it up to the stepper motor and driver, and had the same issue?
I know i am supposed to have the stepper.run() function in the main loop of the program, however i am not quite there with my understanding of program. what do you guys think is causing this issue?
Here is the motor movement code:
Code: [Select]
void moveWorkpieceForward( float distanceToMove )
  int xa=0;
  int xb=0;
  delay( 1000 );
  //delay( 1000*distanceToMove ); // REMOVE
  delay( 1000 );
  //move forward
   while (stepper.currentPosition() != stepsToMove) // Full speed up to 300
     stepper.run();
  //move forward
   stepper.moveTo(stepsToMove); // negative because moving backwards
     stepper.run();
}void moveWorkpieceForward( float distanceToMove )
  int xa=0;
  int xb=0;
  delay( 1000 );
  delay( 1000 );
  //move forward
     stepper.run();
  //move forward
     stepper.run();
flytyer232
Also,
Here is my code as a whole, without using millis(). I figure i should try to debig this one first, as it is the simpler of the two codes. Additionally, i really appreciate it the responses and help from you guys.
Code: [Select]
  int myPin;
  // Constructor
  public:
  myPin = pin;
  void clamp()
  void unClamp()
class punch
  int myPin;
  // Constructor
  public:
  punch( int pin )
  myPin = pin;
  void punchHole()
//board stuff
//pin assignments
const int alertPin = 23;
const int profileSwitchPin = 27;
//float stepsPerInch = 2272.727;
float stepsPerInch = 1408.45;
//profile checking
const int profileSetALength = 21;
const int profileSetBLength = 29;
float profileSetA[ 4 ][ profileSetALength ] = {
float profileSetB[ 4 ] [ profileSetBLength ] = {
  { 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333,2.67,  5.333, 0, 0, 0,0 },  //IS-8-bottom rail
 { 4.000, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 5.333, 2.67, 5.333, 0, 0, 0, 0, 0, 0, 0,0 },                  //IS-6-bottom rail
  pinMode( profileSwitchPin,  INPUT );
  stepper.setMaxSpeed(1500);    //in steps per second
  stepper.setAcceleration(800); //in steps per second
  bool profileSwitch = digitalRead( profileSwitchPin );
    if (profileSwitch) {
      punchProfile(profileSetA[chosenProfile], profileSetALength);
      punchProfile(profileSetB[chosenProfile], profileSetBLength);
    if ( workpieceNeedsToBeRemoved ) {
      if ( resetFreshlyUp ) {
      if ( selectFreshlyUp ) {
        if ( chosenProfile == 3 ) {
         chosenProfile = 0;
          chosenProfile++;
      if ( startFreshlyUp ) {
void punchProfile(float profile[], int profileLength)
  for (int i=0; i < profileLength; i++){
    float distanceToMove = profile[ i ];
      unicyl.punchHole();
  unicyl.punchHole();
  delay( 2000 );
  int xa=0;
  int xb=0;
  delay( 1000 );
  delay( 1000 );
  //move forward
     stepper.run();
  //move forward
     stepper.run();
Robin2
I don't agree. At the very least you will have to do it all over again when you want to re-write the code using millis().
IMHO you are starting at the wrong end.
Write a short program using Accelstepper that makes the motor turn one revolution in each direction with an interval of 1000 milisecs between the movements using millis() to manage the timing.
When that works then start adding other functionality to it.
...R
flytyer232
Robin,
I see your point, i first tried this code, with no timing. See below. i ran into the same issues however, where the forward stroke was only 1.3 inches, and the backward stroke was around 2.1 inches. From then, the movement was consistently was 2.1 inches back and forward.
Any ideas?
Code: [Select]
int movement = 0;
const int steps = 8600; //steps moved, distance
const int small_steps =4300; //small steps moved, distance
//steps that 100 steps equal, in inches
long a=0.044;
float stepsPerInch = 1408.7;
// Define a stepper and the pins it will use
AccelStepper stepper(1,9,8);
  int x =0;
   //x = move_forward_back(4.633);
//check to see if x is equal to 1.
if(stepper.distanceToGo() == 0)
  reset();
if(movement ==0)
  moveMobileCylinderForward(2);
if (movement == 1)
   moveMobileCylinderBackward(2);
 stepper.run();
void reset()
  stepper.stop();
  movement +=1; //increment the movement, to move on to the next phase
  //this function should reset the entire process, stopping the stepper motor
  //Also, should fix the current position as the new zero.
 //The movement +=1 will increemtn it to tick the loop to the next move function
  //move forward
  //move forward
flytyer232
Okay, i tried one more thing, where i hard code 2000 steps. Same thing, the first movement was short of the intended steps, by around 600 steps, or so.....
Code: [Select]
int movement = 0;
long a=0.044;
  int x =0;
  reset();
if(movement ==0)
  moveMobileCylinderForward();
if (movement == 1)
   moveMobileCylinderBackward();
 stepper.run();
void reset()
  stepper.stop();
void moveMobileCylinderForward()
   //move forward
   stepper.moveTo(2000);
void moveMobileCylinderBackward()
   //move backward
   stepper.moveTo(-2000); // negative because moving backward
Robin2
Then don't bother with the second movement until you get the first one correct.
Why are you incessantly calling stepper.moveTo() - that may be what is causing the problem. You should only call it once when distanceToGo() = 0.
...R
flytyer232
Oh. Looking into Accel_stepper, i can see how that could very be the issue, so i do apologize for being an idiot. I tried this, which should only call the moveTo() at the beginning, and when the distance to go is equal to zero..
Code: [Select]
  reset();
  stepper.moveTo(-stepper.currentPosition());
stepper.run();
void reset()
  stepper.stop();
However, it would start the first cycle, like it was half way through already?
I also tried it with just a single movement, forward. Same issue, the first movement was only about half the distance it was supposed to be. from the acceleration stand point, it jolted into a higher speed, than it should. Thus, i wonder if it was skipping some phase of the acceleration phase, as there was a time delay as well? honestly, no idea what is going on here.
Code: [Select]
  reset();
stepper.run();
void reset()
  stepper.stop();
Thanks again for the help
Robin2
Why are you calling stepper.stop()?  If distanceToGo() is 0 then it has already stopped.
Have you tried specifying the starting position with setCurrentPosition()? However I don't see why it would not automatically start at 0.
And why is your program making the motor move in the reverse direction while you still have a problem with the initial move?
How about deleting stepper.moveTo() from setup() ?
...R
