Topic: Using Arduino UNO with DWM1000 (Read 858 times) previous topic - next topic
Jan 04, 2018, 09:24 am Last Edit: Jan 04, 2018, 09:29 am by qassim93
Hi Guys,
I just wanted to update those who are following this thread.
I just received the Arduino Pro mini which is meant to be used with Wayne's PCB and guess what ?
It eliminated the need for Pull-Up or down resistors - because there are ones already built-in in the DWM1000 module as per the datasheet.
So, I successfully tested the Anchor/Tag ranging example and they just work fine.
Now the next step is to calibrate the thing because it gives and initial error of about 0.5 meters when it should be 0 or so.
Thanks !
Im using the pro mini as well... Im just learning this chip, can you point me in the direction of where I can find a pinout diagram?
