Topic: write data into 27C256 EPROM  (Read 2220 times) previous topic - next topic
azlanthetypewritter
hello guys,
i'm new to this forum.
currently my project is to read data on 27C256 EPROM by using arduino mega s sainsmart.
the code that i use is from github
https://github.com/phooky/PROM/blob/master/tools/eeprom_read/eeprom_read.pde
Code: [Select]
#include <stdint.h>
// Set MAX_ADDR to the largest address you need
// to read. For example, for the 27C512 chips,
// you'll want to use a MAX_ADDR of 65536.
// (That's 512 * 1024 / 8.)
// A 27C256 would be 256 kilobits, or 256 * 1024 / 8 =
// 32768.
#define MAX_ADDR 65536L
// On my board, I've connected pins 26-41
// to the A0-A15 lines, and pins 2-10 to the
// Q0-Q7 lines. You'll want to change these
// pin choices to match your setup.
#define A0 54
#define Q0 2
// When you're all wired up, hit the reset button
// to start dumping the hex codes.
  for (int i = A0; i < A0+16; i++) {
    digitalWrite(i,LOW);
    pinMode(i, OUTPUT);
  for (int i = Q0; i < Q0+8; i++) {
    digitalWrite(i,HIGH);
    pinMode(i, INPUT);
  Serial.println("Start Reading\n\n");
void writeAddr(uint32_t addr) {
  uint32_t mask = 0x01;
    if ((mask & addr) != 0) {
    mask = mask << 1;
uint8_t readByte() {
  uint8_t data = 0;
  uint8_t mask = 0x1;
    if (digitalRead(i) == HIGH) {
      data |= mask;
    mask = mask << 1;
  return data;
  uint32_t addr = 0;
  while (addr < MAX_ADDR) {
    for (int i = 0; i < 16; i++) {
      writeAddr(addr);
      uint8_t b = readByte();
      Serial.print(b, HEX);
      Serial.print("\t");
      addr++;
    Serial.println("");
  while (1) {}
the pin is attach directly to arduino as per circuit attach below
The data i get in hex. i save in excel. as per picture below.
actually the data total count is 65536. i just snap just the little bit .
so now the next task is, i want to create a simple board with program to write the data that just read into the new blank EPROM 27C256?
mostly i found EEPROM and all use EEPROM Programmer. and i want to learn to create your own EPROM programmer.
somebody can help me please :'(
i'm new to this EPROM thing
thanks
chucktodd
hello guys,
thanks
You need to read the datasheet for a 27c256 Parallel EEPROM, you will have to make a circuit that can drive Vpp to 13V and Vcc to 6.5V under software control.
Reading data from the chip is easy with a MEGA.  The datasheet shows a flowchart of the programming algorithm, After you construct the circuit to produce the programming voltage it should be easy to implement.
Chuck.
Currently built mega http server, Now converting it to ESP32.
knut_ny
Do reading MUCH more efficient (and easy) by using PORT commands
Ny
