Topic: Failed to open /dev/ttyACM0 (port busy) (Read 493 times) previous topic - next topic
fabriceN
Dear all
I am trying to work with the (new) sparkfun razor IMU 9dof, I wrote a silple sktetch to calibrate the magnetometer:
#include <SparkFunMPU9250-DMP.h> // Include SparkFun MPU-9250-DMP library
//#include <Wire.h> // Depending on your Arduino version, you may need to include Wire.h
MPU9250_DMP imu; // Create an instance of the MPU9250_DMP class
  // Wait for the Serial Monitor to open (comment out to run without Serial Monitor)
  // while(!Serial);
  Serial.println(F("Adafruit 10 DOF Board AHRS Calibration Example")); Serial.println("");
 if (imu.begin() != INV_SUCCESS){
    while (1)
        Serial.println("Failed to initialize MPU-9250, loop forever");
  // Use setGyroFSR() and setAccelFSR() to configure the
  // gyroscope and accelerometer full scale ranges.
  // Gyro options are +/- 250, 500, 1000, or 2000 dps
  imu.setGyroFSR(2000); // Set gyro to 2000 dps
  // Accel options are +/- 2, 4, 8, or 16 g
  imu.setAccelFSR(2); // Set accel to +/-2g
  // setLPF() can be used to set the digital low-pass filter
  // of the accelerometer and gyroscope.
  // Can be any of the following: 188, 98, 42, 20, 10, 5
  // (values are in Hz).
  imu.setLPF(5); // Set LPF corner frequency to 5Hz
  // The sample rate of the accel/gyro can be set using
  // setSampleRate. Acceptable values range from 4Hz to 1kHz
  imu.setSampleRate(100); // Set sample rate to 10Hz
  // Likewise, the compass (magnetometer) sample rate can be
  // set using the setCompassSampleRate() function.
  // This value can range between: 1-100Hz
  imu.setCompassSampleRate(100); // Set mag rate to 10Hz
void loop(void)
  imu.update();
  // Print the sensor data
  Serial.print("Raw:");
  Serial.print(imu.ax);
  Serial.print(',');
  Serial.print(imu.ay);
  Serial.print(',');
  Serial.print(imu.az);
  Serial.print(',');
  Serial.print(imu.gx);
  Serial.print(',');
  Serial.print(imu.gy);
  Serial.print(',');
  Serial.print(imu.gz);
  Serial.print(',');
  Serial.print(imu.mx);
  Serial.print(',');
  Serial.print(imu.my);
  Serial.print(',');
  Serial.print(imu.mz);
  delay(50);
ieee488
Why are you posting your code when the fundamental problem is something else?
fabriceN
Well, because at first glance I was thinking perhaps there is something wrong in the code as well. But you are right, it is something and I do not have any clue so far
Budvar10
Check the device first if it is present on your system and if you have the rights for your credentials.
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
