Topic: MQ-2 Smoke only (Read 317 times) previous topic - next topic
tedo3637
Hi!
I'm using MQ-2 sensor for arduino, and how can i detect smoke only, not all inflammable gases?
I'm using example sketch of MQ-2 Library.
terryking228
The MQ-X series are Taguchi Gas Sensors and their surfaces respond to different chemical substances.
If you want only "Smoke"  or "unclear air" you will need an optical transmission type sensor, I believe.
See THIS google search (Which you mighta done yourself)..
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
tedo3637
Hmm, i saw that and my next question is can i create smoke sensor with obstacle detector?
Delta_G
Aren't smoke sensors already fairly common devices?  I can see three right now from where I am sitting in this hotel suite.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
jremington
Quote
Use a smoke detector.
