Topic: Yun 17.11 Reboot prerelease (Read 18291 times) previous topic - next topic
gpedder
Hi, the links arent' working. Is this project dead?
AgroMeInc
Doesn't seem dead but this thread does.
try these: https://github.com/arduino/yun-go-updater/releases
jhsung97
Finally a chance to try it out ... so far the auto updater is not working. Needs sudo for the tftp daemon, assumes there isn't one already running (closed my existing) and then an IP address conflict (switched off local machine causing the conflict)
I'm still getting a timeout at flashing the boot loader: ...
Flashing Bootloader
tftp 0x80060000 u-boot-arduino-lede.bin
eth0 link down
FAIL
eth1 link down
FAIL
Using eth0 device
TFTP from server 192.168.99.200; our IP address is 192.168.99.201
Filename 'u-boot-arduino-lede.bin'.
Load address: 0x80060000
Loading: T T T T T T
expect: timer expired after 30 seconds
Could not get your IP address, check your network connection
*Update*: seemed like the ip address setup was a bit finicky about being on an existing network, got it working after isolating on a cross over cable.
Nice to see an update on the Yun, off to explore ! Thanks :)
Flashing Bootloader
eth0 link down
FAIL
eth1 link down
FAIL
Using eth0 device
jhsung97
Hello,
TFTP server is your computer. run TFTP util on your computer.
Then on u-boot status, put the cmd 'setenv serverip your ip'
 Next, put 'setenv ipaddr board's ip ' . You can use any thing as board ip if
it is in your network. Then re try.
Have a good luck.
jhsung97
Hello, thanks to new update.
I tried it but got a fail. So, I set up it manually resulting in a success.
Anyone who try it manually should be careful at some points.
You should use a new disk-expander util because old one yields a insufficient memory alarm.
(use the new version in the go-update package).
Next, you should update your u-boot at first due to a large package.
I am really happy due to this new update. I have some problems in using the python in the old version
(especially pip was not working due to certification problem). Now, it works fine.
Thanks.
AgroMeInc
Hi, I have tried everything and it's not working. I tried on WiFi anb on Wired network too. Actually the Mac is on WiFi and the Yún is connected via ethernet cable. Why does it always stop with: Could not get your IP address, check your network connection
Code: [Select]
Enter server IP address: 192.168.1.176
Enter board IP address: 192.168.1.198
Found port: /dev/cu.usbmodem1421
USB ID     2341:8041
USB serial
Using it
Restarting in bootloader mode
Get port list before reset
Wait for the port to disappear
Wait for the port to reappear
Found upload port:  /dev/cu.usbmodem1421
Flashing with command:/Users/alejandroimass/Downloads/Yun GO Updater 17.11/avr/bin/avrdude -C/Users/alejandroimass/Downloads/Yun GO Updater 17.11/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/cu.usbmodem1421 -b57600 -D -Uflash:w:/Users/alejandroimass/Downloads/Yun GO Updater 17.11/avr/YunSerialTerminal.ino.hex:i
Rebooting the board
Using stop command: ard
Got shell: ar7240
fwShell: ar7240
Flashing Bootloader
182492 bytes sent
Setting up IP addresses
ballscrewbob
@AgroMeInc
If it already picked up an IP via DHCP it will be listed in your router DHCP list.
Worth checking that out as mine went right into DHCP after the update and the IP's were no longer viable Mine jumped into the system as 192.168.0.12 (which is in my subnet)
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
andsoforth
Does this stuff work for the Arduino Yun Rev 2? It doesn't say so specifically and it was created well before the Rev 2 was released.
Please clarify.
