Topic: Arduino won't Upload (Read 285 times) previous topic - next topic
EMDTEAM10
Hello,
my arduino says
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 6558 bytes (20%) of program storage space. Maximum is 32256 bytes.
Global variables use 576 bytes (28%) of dynamic memory, leaving 1472 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x98
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x98
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x98
it won't upload my code. I updated the libraries, my computer, I restarted. Still the same problem.
sterretje
Not sure, but did you select the correct port? And just to make sure, your board is an Uno?
Did you try the loopback test as described in one of the stickies at the top of this forum section? Result?
Is it recognised in the device manager? Is it an original or a clone (maybe with CH340 usb-to-ttl chip which needs a driver).
Do you have anything connected to pins 0 and 1?
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
