Topic: controlling speed of a motor (Read 517 times) previous topic - next topic
djeh1usa
Hi. I have a pump running with a Arduino Uno+motor shield +9V battery.
I run couple of test, it works great but I would like to control the speed of the pump by adding a "regulator"> see photo attached. I tried to put it between the motor shield and the pump but it does not work..I was wondering if I need a special library to control that "regulator"...to make it work! thanks
My other idea might be to define that controlled on the analog pin, but I wonder how to deal with the 4 connector( see back picture) ( Power-, power+, Motor+, Motor-), how to define them?
Thanks!
Robin2
Images from Original Post so we don't have to download them. See this  Image Guide
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Robin2
Why not just control the speed of the pump with the motor shield?
...R
MarkT
9V battery?  That's something you'll need to address first.
djeh1usa
in fact, it turns out I can control the pump directly with the motor shield, without going through Arduino. (v battery was enough to start the pump...Only pb, I can not reverse the flow direction, I only control the speed of it.
Robin2
As you have not told us how you are doing that I, for one, have no idea how to help you.
...R
