Topic: need help with clock project with PCF8523  (Read 563 times) previous topic - next topic
nickbuhling
Hi everyone,
I am currently working on THIS project but instead of his DS3231 RTC I am using the PCF8523. Now when I run his code, my display writes a certain time and then sticks to that time forever. I have been looking in every corner of the internet for a sollution without succes, so maybe anyone of you can help me.
This is his code:
I tried changing RTC_DS3231 rtc; to RTC_PCF8523 rtc; and although it did upload it still did not work
Code: [Select]
#include <Wire.h>
#include <Adafruit_IS31FL3731.h>
#include "RTClib.h"
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
byte LEDBRIGHTNESS = 32; // 0-255
int previousMinute = -1;
bool DEBUG = false;
// If you're using the full breakout...
Adafruit_IS31FL3731 matrix = Adafruit_IS31FL3731();
// If you're using the FeatherWing version
//Adafruit_IS31FL3731_Wing matrix = Adafruit_IS31FL3731_Wing();
//3x9 number digit font bitmaps
byte one[]= {B01000000,
             B11000000,
             B01000000,
             B01000000,
             B01000000,
             B01000000,
             B01000000,
             B01000000,
             B11100000};
byte two[]= {B11100000,
             B00100000,
             B00100000,
             B00100000,
             B11100000,
             B10000000,
             B10000000,
             B10000000,
             B11100000};
byte three[]= {B11100000,
               B00100000,
               B00100000,
               B00100000,
               B11100000,
               B00100000,
               B00100000,
               B00100000,
               B11100000};
byte four[]= {B10100000,
              B10100000,
              B10100000,
              B10100000,
              B11100000,
              B00100000,
              B00100000,
              B00100000,
              B00100000};
byte five[]= {B11100000,
              B10000000,
              B10000000,
              B10000000,
              B11100000,
              B00100000,
              B00100000,
              B00100000,
              B11100000};
byte six[]=  {B11100000,
              B10000000,
              B10000000,
              B10000000,
              B11100000,
              B10100000,
              B10100000,
              B10100000,
              B11100000};
byte seven[]={B11100000,
              B00100000,
              B00100000,
              B00100000,
              B00100000,
              B00100000,
              B00100000,
              B00100000,
              B00100000};
byte eight[]={B11100000,
              B10100000,
              B10100000,
              B10100000,
              B11100000,
              B10100000,
              B10100000,
              B10100000,
              B11100000};
byte nine[]={ B11100000,
              B10100000,
              B10100000,
              B10100000,
              B11100000,
              B00100000,
              B00100000,
              B00100000,
              B00100000};
byte zero[]={ B11100000,
              B10100000,
              B10100000,
              B10100000,
              B10100000,
              B10100000,
              B10100000,
              B10100000,
              B11100000};
char *noArray[] = {zero, one, two, three, four, five, six, seven, eight, nine};
#ifndef ESP8266
  while (!Serial); // for Leonardo/Micro/Zero
#endif
  Serial.println("ISSI manual animation test");
  if (! matrix.begin()) {
    Serial.println("IS31 not found");
    while (1);
  Serial.println("IS31 Found!");
String convertIntTo2DigitString(int i)  {
  String s = String(i);
  if (i < 10)  {
    s = '0'+s;
  return s;
  DateTime now = rtc.now();
  int currentMinute = now.minute();
  int currentHour = now.hour();
  if (DEBUG)  {
    currentHour = currentMinute;
    currentMinute = now.second();
  if (previousMinute != currentMinute)  {
      previousMinute = currentMinute;
      String min = convertIntTo2DigitString(currentMinute);
      String hour = convertIntTo2DigitString(currentHour);
      matrix.clear();
      matrix.drawBitmap(0, 0, (byte*)noArray[(int)hour[0]-'0'], 3, 9, LEDBRIGHTNESS);
      matrix.drawBitmap(4, 0, (byte*)noArray[(int)hour[1]-'0'], 3, 9, LEDBRIGHTNESS);
      matrix.drawBitmap(9, 0, (byte*)noArray[(int)min[0]-'0'], 3, 9, LEDBRIGHTNESS);
      matrix.drawBitmap(13, 0, (byte*)noArray[(int)min[1]-'0'], 3, 9, LEDBRIGHTNESS);
Koepel
What is "hour[0]" ?
You want to convert an integer to an integer, and to do that you convert the integer to a String object and then try to convert the String object to an integer (but that fails). Why not use the integer that you started with ?
