Topic: Split a float in 2 bytes (Read 416 times) previous topic - next topic
ammarqs
I have a floating number for example 54.354 and i want to send to over modbus to another device. I wanted to split this number into 2 bytes and send it.
Can anyone help with any function that could split a float into 2 bytes.?
Thanks
aarg
Nobody can. A float occupies 4 bytes. You can split it into 4 bytes...
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
ammarqs
OK so how do i split it in 4 bytes?
BulldogLowell
a union
Code: [Select]
union MyUnion{
  uint8_t myByte[4];
  float myfloat;
ammarqs
I dont understand. How do i use this?
aarg
Did you research it at all?
BulldogLowell
Code: [Select]
union MyUnion{
  uint8_t myByte[4];
  float myfloat;
MyUnion myUnion;
//Somewhere in a function....
myUnion.myfloat = 3.1216;
for (int i = 0; i < 4; i++)
  Serial.println(myUnion.myByte[i]);
GOOGLE
ammarqs
Quote
I am doing it as we speak. Replied to quick on that tip. Sorry about that.
Thank you BulldogLowell
ammarqs
Quote
union MyUnion{
  uint8_t myByte[4];
  float myfloat;
MyUnion myUnion;
  Serial.println(myUnion.myByte);
I tried the above code and it returned:
Code: [Select]
75
200
71
64
i tired different floats and it displayed different combinations. I dont understand how does union do its conversaion?
Whandall
#9
Dec 08, 2017, 01:38 am Last Edit: Dec 08, 2017, 01:42 am by Whandall
It just reinterprets the memory that holds the float as an array of bytes, there is no conversion.
If you want to learn more about the internal format of floating point numbers have a look at
https://www.h-schmidt.net/FloatConverter/IEEE754.html
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
larryd
#10
Dec 08, 2017, 01:44 am Last Edit: Dec 08, 2017, 02:01 am by larryd
Quote
In the UNION, your float variable has 4 bytes of memory reserved.
Those 4 bytes of memory are physically shared with the 4 elements of array myByte[].
No technical PMs.
The last thing you did is where you should start looking.
Delta_G
#11
Dec 08, 2017, 01:47 am Last Edit: Dec 08, 2017, 01:48 am by Delta_G
Code: [Select]
75
200
71
64
Those are the four bytes your float is made of.  You wanted to split a float into 4 bytes and those are the 4 bytes.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
jremington
#12
Dec 08, 2017, 04:32 am Last Edit: Dec 08, 2017, 04:33 am by jremington
Quote
Were you thinking to send those (4) bytes somewhere in particular, and do something with them once they arrived, or did the thought process simply stall out?
gfvalvo
a union
Or a pointer:
Code: [Select]
  float myFloat;
  float *myFloatPtr;
  delay(2000);
  myFloat = 100.5;
  myFloatPtr = &myFloat;
  // Using pointer dereferencing
  for (uint8_t index=0; index<4; index++) {
    Serial.println(*((uint8_t *)myFloatPtr + index), HEX);
  // Using array notation
    Serial.println( ((uint8_t *)myFloatPtr)[index], HEX);
void loop() {}
