Loading...
Pages: [1]   Go Down
Author Topic: connecting this relay to a pin  (Read 486 times)
South East USA
Offline Offline
God Member
View Profile
This relay is rated at 5v, 30 mA on the coil, so can it be connected directly to an i/o  pin on my board?
http://www.sparkfun.com/products/524
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
In theory, you could, since the pins are rated to source 40 mA - but I wouldn't (unless you're only using one or two, and have a good reason to avoid using a buffer circuit). If you do, remember you still need a snubber diode across the coil...
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Yes, but you should wire a diode across the coil terminals in reverse bias to suppress transients when de-energizing.
Lefty
Logged
South East USA
Offline Offline
God Member
View Profile
Ah yes, seems like that's a fly by or flyback diode...
something like a 1N4448, or does it need to handle more power like a 1n4006?
thanks
Logged
Offline Offline
Brattain Member
View Profile
thanks
Not sure, but I like 1 amp diodes for things like that, so my vote would be any of the 1N400x series.
Lefty
Logged
Hyderabad , India
Offline Offline
God Member
can't help not to think arduinaizing something !
View Profile
WWW
hi there i have a question how do you people know about that diode and ic names (numbers?)
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
because we have been using them for years. They seep inside your skin.
My telephone extension at work is 741 - now how many of you know what one of those are - been using them for 40 years.
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
hehe! okey well i thought that we should somehow learn that somewhere  !  smiley-wink
Logged
Leighton Buzzard, UK
Offline Offline
Edison Member
View Profile
hee hee love the number
op amp as I recall?!?
Logged
there are only 10 types of people
them that understands binary
and them that doesn't
Offline Offline
Newbie
View Profile
Fyi - this place sells a board with 4 relays that you can connect directly to an Arduino output pins.  It is not a "shield" that mounts on the arduino but comes with wires for each relay that are easy to connect to whatever arduino board you have. Also you have to provide a separate 12V supply to the relay board to activate the relays. Here is the link: http://www.pimpmyprop.com/RB4RelayBoardDetails.htm.
Logged
Pages: [1]   Go Up
Print
Jump to:
