Topic: Ethernet MP3 Player (Read 14154 times) previous topic - next topic
kalum
oh great ! I'll be waiting for it!
I just replied to your first email and I sent you the code that I wrote so far, but you may not need to look at it if you develop your idea. At the moment I can get a 128k/s icecast stream without a problem using a baudrate of 230400, but only if I redirect it to the USB port. Copying to the rMP3 SD card fails. If you can manage to make a direct protocol, then I think it will be very straightforward for me to finish.
The main issue with a ethernet streaming mp3 player is the buffering of data packets. The AVR has only 2k of RAM which is not enough to buffer the TCP/IP packets form the ethernet controlller, buffering is needed as packets form the internet can be corrupted etc, so the ideal setup would be the avr connected to the ethernet controller and additional ram available via a SPI interface. The SPI interface can also be shared with the vs1053 mp3 decoder chip to complete the ethernet based mp3 streaming media player. This kind of setup is seen on the vs1053 page for the PIC family and ARM.
http://www.watterott.net/projects/webradio-arm
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en536047
The key issue is the code to interface the external SRAM to buffer the ethernet packets. If that can be sorted out, you will have your avr based streaming mp3 player :)
maniacbug
The main issue with a ethernet streaming mp3 player is the buffering of data packets. The AVR has only 2k of RAM which is not enough to buffer the TCP/IP packets form the ethernet controlller.
The VS1053 has a 2K internal memory dedicated to buffering incoming data.  I wonder if that would be enough of a buffer, so I'm going to try this out.  At 160kbps, that buffer holds 100ms of audio, so you've got that long to fill it up with data over the network.  In theory, that should be plenty of time.  It will be interesting to try!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
