Loading...
Pages: [1]   Go Down
Author Topic: Synth / Sound Chips - Or other ideas...  (Read 1504 times)
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Just reviving the talk we had in the old forum. How about using the Arduino to get some nice SID, Synth, Analog, sampled, etc ... sounds.
Here's a great project using the ATmega88, not Arduino based, but still, check this out.
http://www.linusakesson.net/chipophone/index.php
"The synthesizer is implemented on an ATmega88, an 8-bit microcontroller with 1 kB of RAM and 8.5 kB of ROM. It receives MIDI data at a jumper-configurable baud rate and produces a 12-bit mono line out signal. What follows is a brief architectural overview."
It has 8 voices!!!  smiley-eek-blue
I will post some other links and ideas soon.
Best Regards, WilliamK
Logged
Portugal
Offline Offline
God Member
View Profile
Is a very very smart programmer and I bet that everything is done using assembly, and it doesnt have a lot of interrupts firing so you can have nice things like millis, or serial comms.
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Someone from another thread just pointed me out to this:
http://elm-chan.org/works/sd20p/report.html
255 Voices?
Wk
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Ok, I see now, its 255 SOUNDS, not voices. ;-)
But how about this one:
http://elm-chan.org/works/mxb/report.html
This is a great thing! Hear the audio example. (save to .mp3 to open with WinAmp)
Now a question, what's the max khz of the ATmega328 PWM output? Or the PWM is done in Software?
Wk
Logged
Brazil
Offline Offline
God Member
Wusik Dot Com
View Profile
WWW
Nevermind, I see that those ATtiny chips has something called "High Frequency PWM" while the regular Arduino chips don't.
So I wonder, if maybe I could use the Arduino IDE like this:
http://hlt.media.mit.edu/wiki/pmwiki.php?n=Main.ArduinoATtiny4585
But add some extra code to take advantage of those high frequency PWM outputs. The ATtiny45 has 2 High Frequency PWM outputs, which could generate 16-bit High Quality output from the other page above. Just need to figure out the whole thing first. ;-)
Wk
Logged
Portugal
Offline Offline
God Member
View Profile
Atmega328p also as high speed pwm, but the maximum pwm resolution of both chips is 10bits, using 8bits pwm you can play PCM audio very very easily..
Logged
Pages: [1]   Go Up
Print
Jump to:
