Topic: Need official ethernet shield jack vertical dimension (Read 2907 times) previous topic - next topic
liuzengqiang
So I am revising my Phi-1 shield design to make it compatible with the official Ethernet shield. Problem is, I don't have the shield. I don't see myself having enough money and using that shield. I want to know how tall the Ethernet jack is. Could someone measure it in mm or inch for me? Thanks.
From pics I can find, I sense that it is taller than the female headers, which is my concern. I can work out the lateral dimensions from the design files but not the height. Thank you!
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
djc
Go to http://arduino.cc/en/Main/ArduinoEthernetShield
Click on http://arduino.cc/en/uploads/Main/arduino-ethernet-shield-05-reference-design.zip
Unzip.
Open .sch file in Eagle.
Right click on Ethernet connector.
Choose 'Properties'.
Highlight 'SI-40138'.
Press Ctrl-C.
Open Google.
Press Ctrl-V.
Press Enter.
Download http://www.aquaphoenix.com/hardware/ledlamp/reference/si-40138_data_sheet.pdf
Am I missing something here?
liuzengqiang
djc,
Thank you! I was thinking too much about having an actual ethernet shield and measuring with a ruler. I didn't think along the line you pointed out. So the entire thing is 15.12mm tall!
liuzengqiang
Just did a measure, 15.12mm seems pretty major. Did anyone stack any shields above the official ethernet shield? What's your experience? Do I have to use stacking headers?
