Topic: Arduino Bandgap Reference (Read 4468 times) previous topic - next topic
neilrudds
Hi, Hope someone can help probably basic electronic but cant figure it out.....
I want to measure the VIN voltage to my board and ive written the code ok but it needs compensated for the fact i have a 10K resistor connected on pin 14! therefore if in input:
       4.87V i get a bandgap ref reading of 3.30V as ive lost 1.57V accross the 10K resistor @ 0.487 mA
or    4.22V i get a reading of 3.01V due to the loss of 1.21V accross the 10K resistor @ 0.422 mA
can anyone derive a formula to compensate for this and correct for different values.. XD XD XD.......?
Thanks Neil.
retrolefty
Your verbal discription is not real clear to me. What is needed is a simple schmatic drawing of how you have wired everything up and the values of the components. I'm not sure at all that you are using the term band-gap properly.
Lefty
gardner
It would help if you could draw a circuit and explain more carefully what you are trying to do.  I *think* what you are saying is that you want to be able to build a voltage divider that will enable you to measure your main Vin voltage, using the Arduino built-in 1.1V A2D reference.  Is that correct?
Grumpy_Mike
Why?
There is no need to wire anything to anything. You need to write software to access the analogue multiplexers above 7. One of these is the internal band gap. By measuring that with Vcc as the reference you can work out what the value of Vcc is.
neilrudds
Thanks for the replys: heres my circuit which i designed a few months ago:
http://www.neilrudds.co.uk/wp-content/uploads/2011/01/PCB.png
origionally I wasnt aware of the bandgap ref feature until i came accross a youtube vid.
As you can see on pin 14 there is a 10K resistor which is connected to ground, will this effect the V Bandref?
What im trying to do is get the VIN value, but when I input 4.87V i get a reading of 3.30 Volts! and i dont kno why?
Here is my code:
// Get the Vin see pin(14) on datasheet
int reference; // Stores Refrence val
float VIN; // Stores the Input Voltage
void Get_VIN(void)
  reference = analogRead(14); // 1.1Volts!
  VIN = ((1.1/reference)*1023); // Convert to VIN , 1.56 dropped accross R4 10K
  Serial.println(reference);
  Serial.println(VIN);
gardner
  reference = [color=#CC6600]analogRead[/color](14); [color=#7E7E7E]// 1.1Volts![/color]
I suspect you may be mixing up Arduino pin numbering with ATMEL AVR ping numbering.  Arduino (on a 168) doesn't have an analogue input numbered 14.  Please have a look at the reference manual for analogRead() and analogReference().  http://arduino.cc/en/Reference/AnalogRead
You are going to have code more like:
analogReference(INTERNAL);
result = analogRead(0);
cjands40
Actually, "14" is the correct ADMUX value to read the internal bandgap voltage but the Arduino analogRead function no longer allows access to it (as of IDE 18, I believe).
neilrudds
Problem solved ... Just incase any1 else wants to know i found this : http://code.google.com/p/tinkerit/wiki/SecretVoltmeter
long readVcc() {
   long result;   // Read 1.1V reference against AVcc
   ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
   delay(2); // Wait for Vref to settle
   ADCSRA |= _BV(ADSC); // Convert
   while (bit_is_set(ADCSRA,ADSC));
   result = ADCL;
   result |= ADCH<<8;
   result = 1126400L / result; // Back-calculate AVcc in mV
   return result;
   Serial.println( readVcc(), DEC );
Coding Badly
Bear in mind that the constant...
...varies a bit from processor to processor.  If you need an accurate VCC value, you will have to determine the actual bandgap voltage for your processor.
Grumpy_Mike
Or they could have read my reply #3 yesterday.
Coding Badly
The destination isn't nearly as important as the journey.  @neilrudds just wanted to take the long scenic route.   ;)
