Topic: MIDI Serial Port (Read 7888 times) previous topic - next topic
OzGrant
G'day,
Is it possible to use NewSoftSerial so that another pin(port) for the MIDI signal in the MIDI library is used.
Tks
AndrewGarza
Is there a MIDI library? And don't you only use port 1 (TX) port for outputting MIDI? What port would you rather use?
http://twoguysonebit.blogspot.com/
http://guitarduino.blogspot.com/
robtillaart
Looking at the NewSoftSerial.cpp file it has an entry for 31250 baud in its tables which is IIRC the MIDI speed. Start/stop/parity bits unkown.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
OzGrant
Not sure if I explained my problem correctly.
The MIDI library uses digital pins 0 & 1 and I want to use pins 8 & 9.
The command MIDI.begin() does not give you the option of altering the serial port, and am hoping that NewSoftSerial library can be used to achieve this.
Can this be done.
robtillaart
Do you have an URL to the MIDI library to peek into the code?
Rob Tillaart
Grumpy_Mike
Quote
Yes that is because it uses the hardware serial connections. To make the library use the softwa  serial routines you will have to hack it so that all the references to the serial port now refer to the software serial commands.
OzGrant
Rob,
Am using theV2.5  MIDI library from the playground http://www.arduino.cc/playground/Main/MIDILibrary.
Will now start to look at how to hack it.
OzGrant
Is it possible to use pin 1 (TX) to communicate with the USB and Pin 0 (Rx) to accept MIDI inputs.
That way I can use to use the existing MIDI library.
I need to use the USB port to send the MIDI date so that I can read it on the PC.
Grumpy_Mike
Quote
No you can't run the hardware at different baud rates.
robtillaart
@OzGrant
Had a quick view in the midilib and somewhere in the top of the CPP file there is    #define UART Serial    which is used through the code as Serial port.
Quick hack:
- include the NSS library,
- declare an instance of NSS e.g. MidiSerial
- do a global search/replace of UART with MidiSerial
Better:
- accept param TX and RX in the constructor (default 0 & 1 to be BW compatible)
- if 0 and 1 => use hardware serial
- if other pinnr's => use NSS
Rob Tillaart
OzGrant
Rob,
Yup found that declare, so will give it a shot. Haven't done this level of program altering in a library, so it should be interesting.
Thanks for the pointer.
nickvd
I haven't really dug into the code, but I am using the Midi library (notice that it is not all-caps) from here: http://timothytwillman.com/itp_blog/?page_id=240
You initialize the class using:
Code: [Select]
Midi midi(Serial);
So it should be as simple as passing in your nss object to the midi constructor...
(i also find this midi library much more versatile for midi-input)..
OzGrant
Timothy,
Looks like your MIDI Lib is what I'm after.
Down loaded it (the tgz extension ended up as a .tar) but my winzip ver 14.5 gave me the msg
"Error reading header after processing 0 entries"
Does this mean WinZip does not do tar files or is something else required.
Grant
nickvd
I used izarc without issues... it's free and imo better than winzip
OzGrant
Tks Nick (got the name correct this time)
Downloaded the Lib Ok and unzipped with IzArc.
So will now see if I can use the other port.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
