Topic: "call/select" multiples LEDs (Read 929 times) previous topic - next topic
jmatos448
Dec 17, 2017, 11:20 pm Last Edit: Dec 17, 2017, 11:44 pm by jmatos448
Hii,
I've got something like this
int led0 = 2;
int led1 = 3;
int led2 = 4;
   pinMode(2, OUTPUT);
   pinMode(3, OUTPUT);
   pinMode(4, OUTPUT);
   digitalWrite(led0, HIGH);
   digitalWrite(led1, HIGH);
   digitalWrite(led2, HIGH);
my question is, how can i get something like this??
   digitalWrite(led0, led1, led2, HIGH);
instead of go line by line, set the 3 led in a sngle line.
Grumpy_Mike
Quote
Code: [Select]
digitalWrite(led0,HIGH);
digitalWrite(led1,HIGH);
digitalWrite(led2,HIGH);
dougp
I suspect what you want is a for loop.  Not one line but close.  You'll also need to read up on arrays.  An array is where you store the pin numbers that the for loop will reference to do things like setting pinModes.
The IDE has examples at - File/examples/5.control.
Everything we call real is made of things that cannot be regarded as real.  If quantum mechanics hasn't profoundly shocked you, you haven't understood it yet. - Niels Bohr
No private consultations undertaken!
TonyWilk
Do you mean you want a function like:
Code: [Select]
void digitalWrite3( int a, int b, int c, int hilo )
 digitalWrite( a, hilo );
 digitalWrite( b, hilo );
 digitalWrite( c, hilo );
//then in your setup(), you can call that function like:
digitalWrite3( led1, led2, led3, HIGH );
Yours,
  TonyWilk
septillion
Fixed it:
Code: [Select]
void digitalWrite3(const byte a, const byte b, const byte c, const bool hilo )
Pin numbers are byte/uint8_t, not int. For dark reasons the value is a uint8_t as well but you just want to use HIGH/LOW / true/false so a bool will do.
But in reality, using arrays is the right way. The moment you start numbering stuff => arrays make it a lot easier.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
TonyWilk
#5
Dec 19, 2017, 06:31 pm Last Edit: Dec 19, 2017, 06:59 pm by TonyWilk
I think that until the OP (hello?) comes back with more info, it's hard to say what he wants.
Loop? Array? - that's making a bit of an assumption.
Based on just what he asked, he could be asking how to write a variadic function...
Setting a random selection of LEDs by doing: setLeds( HIGH, led1 ) or setLeds( LOW, led1, led2, led4 ) might be handy. (*)
Yours,
  TonyWilk
(*) but interesting if you're mixing int's and bytes for pin numbers, compiler's not going to coerce that for you - could just write multiple functions I suppose, messy tho'.
darkgiuseppe
I am more interested on why the OP wants to do this. Maybe we can steer them to a different solution based on why they want this one line feature.
Need parts? Check out my new store! http://centipedestudio.com
Happy making!
