Topic: Panel mount jack (Read 1 time) previous topic - next topic
SouthernAtHeart
I'm wanting a panel mount jack for an enclosure, that I can plug a servo into.  I'm wondering what type of plugs/jacks would work.  I've normally used an 1/8" stereo plug, but wondered if there were other options.
Grumpy_Mike
Any sort of plug would work, there is a world of choice out there.
robtillaart
Be aware that some plugs cause a short circuit when plugging in/out. This can trigger anything including unwanted effects like damage. -> that makes the world of choice a bit smaller.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
cr0sh
Basically - just about any coaxial plug/jack, like the OP's original 1/8" stereo plug/jack; such should be reserved for very low-voltage signals only, where shorts aren't an issue.
For a servo, though - you could do what the RC hobby world does, and just have exposed 3-pin male headers to plug the servos into - fairly standard and expected.
If, however, such connections need more protection from being unplugged, four-pin RJ11 plugs and jacks are a robust and easy-to-use (not to mention common) solution.
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
SouthernAtHeart
Quote
Great! I wondered about them, just how much current they can handle.  I'm getting a large full rot. servo from SparkFun.  I can't find out what current it draws, nor do I know what an RJ11 Jack can handle.  But I'd guess half an amp for the servo, and probably an 1amp for the jack?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
