Topic: Need Short Program Written Today (Read 2300 times) previous topic - next topic
scolberg
I need a version of the code neccesary to make the prop dropper described here work.   http://www.nutsvolts.com/index.php?/blog/post/the_halloween_prop_dropper/
I can afford 30 USD
Functionality needed.
When triggered by a PIR a standard servo rotates 90 degrees, an LED is lit,  the program pauses 10 seconds, LED Off, a second continious rotation servo rotates for a variable time.  The variable time is controlled by a potentimeter.  Program ignores the trigger for 15 seconds and then monitors the trigger.
Contact me directly scarytinker at dslextreme.com
doublet
#1
Feb 17, 2011, 09:36 pm Last Edit: Feb 17, 2011, 09:54 pm by doublet Reason: 1
Do you still need it?
EDIT:
Here's a program to steer you in the right direction - I don't know how to drive a continuous servo:
Code: [Select]
#include <Servo.h>
Servo servo_normal;
int PIR_pin = 1; // port of the PIR
int pot_pin = 1; // port of the potentiometer
int LED_pin = 1; // port of the LED
int servo_normal_pin = 1; // port of the normal servo
int servo_cont_pin = 1; // port of the continious servo
int pot_value = 0;
int servo_value = LOW;
int servo_normal_value = 0;
  servo_normal.write(0);
  pinMode(PIR_pin, INPUT);
  pinMode(pot_pin, INPUT);
  pinMode(LED_pin, OUTPUT);
  pinMode(servo_normal_pin, OUTPUT);
  pinMode(servo_cont_pin, OUTPUT);
  servo_value = digitalRead(PIR_pin);
  if(servo_value = HIGH){
    // motion detected
    if(servo_normal_value == 0 || servo_normal_value == 90){
      servo_normal_value += 90;
    } else{
    servo_normal.write(servo_normal_value);
    digitalWrite(LED_pin, HIGH);
    delay(10000);
    digitalWrite(LED_pin, LOW);
    pot_value = analogRead(pot_pin);
    // add the continuous servo part here
    delay(15000);
  } else{
    // this will execute when there is no motion detected
doublet
You will have to add the contuous servo part yourself, as I said, I've never worked with one. Also, be aware that the 'rotate servo 90°' part will do that only once, I programmed it as you asked. However, in the video, it seems like it does that multiple times. This code should do like in the video:
Code: [Select]
#include <Servo.h>
Servo servo_normal;
int pot_value = 0;
    // motion detected
    for( int loopvar; loopvar < 10; loopvar++){
      } else{
      delay(250);
    delay(10000);
    delay(15000);
  } else{
