Author Topic: ATtiny85 Pin Change Interrupt Problem  (Read 7802 times)
Denver
Inactive - PM
I'm trying to use pin change interrupts with the ATtiny because I have to use the INT0 pin for SCK in I2C.
I can trigger the interrupt, but after it fires, it runs through setup() again. It may be just rebooting - with no bootloader it's hard to tell.
The attachInterrupt() with INT0 works fine.
I've tried a few different techniques and vectors [ISR (PCINT1_vect), SIGNAL (SIG_PCINT)] with similar results.
I may be doing something basically wrong here, but I can't figure out what.
Here is a sample that demonstrates the problem . . .
/* IR Receiver Test 2       GOES BACK TO MAIN WHEN I USE ISR
 * SETUP:
 * ATtiny Pin 1 = (RESET) N/U                      ATtiny Pin 2 = (D3) IR OUTPUT PIN
 * ATtiny Pin 3 = (D4) to LED1                     ATtiny Pin 4 = GND
 * ATtiny Pin 5 = D0/SDA on GPIO                   ATtiny Pin 6 = (D1) Piezo
 * ATtiny Pin 7 = D2/INT0/SCK on GPIO              ATtiny Pin 8 = VCC (2.7-5.5V)
#define LED1_PIN         4              // ATtiny Pin 3
#define PIEZO_PIN        1              // ATtiny Pin 6
#define IR_PIN           3              // IR sensor - ATtiny Pin 2
void setup(){
  pinMode(LED1_PIN,OUTPUT);             // for general DEBUG use
  pinMode(IR_PIN,INPUT);                // IR on pin 3
  digitalWrite(IR_PIN, HIGH);           // turn on pullup resistor
  Blink(LED1_PIN,3);                    // shows it's in setup
  //tone(PIEZO_PIN,2500,1000);          // shows it's in setup (not supported with MIT core)
  delay(1500);
  //  attachInterrupt(0,IR_ISR,FALLING); // THIS METHOD OF ISR WORKS
  // Setup pin change interrupt . . .
  // METHOD 4: *************
  PCMSK |= (1<<PCINT3);    //  tell pin change mask to listen to D3
  GIMSK  |= (1<<PCIE);     // enable PCINT interrupt in the general interrupt mask
  sei();                   // Enable all interrupts
void loop(){
  //tone(PIEZO_PIN,2000,200); // when used makes different pitch than in setup()
  delay (1500);
  digitalWrite(LED1_PIN,LOW);
SIGNAL (SIG_PCINT) {    // METHOD 4: *************
  //void IR_ISR(){      // STANDARD METHOD WORKS
  digitalWrite(LED1_PIN,HIGH);
void Blink(byte led, byte times){ // poor man's GUI
  for (byte i=0; i< times; i++){
    digitalWrite(led,HIGH);
    delay (400);
    digitalWrite(led,LOW);
    delay (175);
I'm stumped. Any help is appreciated.
« Last Edit: February 10, 2011, 06:12:15 pm by BroHogan » Logged
"Data is not information, information is not knowledge, knowledge is not understanding, understanding is not wisdom."
~ Clifford Stoll
Dallas
Shannon Member
Rather than help troubleshoot, can I interest you in a working library?  It uses less memory and should be a bit faster than the "stock" pin-change interrupt code.
Denver
Inactive - PM
Sure! A working library for what? Interrupts? IR?
If it's for IR, I'd prefer an int only when it receives a signal, rather than a timer int that going off every x ms.
As I said, I need pin 7 free for I2c.
In any case, I'll be happy to look at a lib.  : smiley-grin
~ Clifford Stoll
Dallas
Shannon Member
I'm afraid you'll be a bit disappointed.  It's just for pin-change interrupts on tiny processors.  But it is well debugged.
The Tiny Core includes a write-only software Serial (Tiny Debug Serial).  All you need is a TTL serial converter (an Arduino will work).  It beats the heck out of LED debugging.   smiley-wink
Denver
Inactive - PM
Not disappointed at all! Pin change interrupts is exactly what I need.
(The ability to detect rising and falling would be great too!)
The serial sounds interesting. I have a cable. Yep, counting LED flashes is no fun. (Normally I use an I2C 2x20 display.)
In any case, thanks! I look forward to checking it out.
John
~ Clifford Stoll
Portugal
Just read the datasheet....
Pin change interrupts are sort of global to each port, after having a PCINT you must write some code to determine wich pin as changed and then react accordind, its all in the datasheet...
That and google avr pin change interrupt..
Denver
Inactive - PM
Senso,
I assumed
Would only cause the INT to fire with D3, but I'll look at the data sheet and google some more.
My understanding of what your saying is that I need some code in the ISR - correct?
 In any case, thanks for the hint.
~ Clifford Stoll
nr Bundaberg, Australia
Only if there are two or more possible interrupt sources. If you only have one then by definition the interrupt comes form that pin and there's no need to figure anything out.
______
Rob
Dallas
Shannon Member
Bah!  Where's the fun in that!
@BroHogan...
Call attachPcInterrupt in exactly the same fashion as attachInterrupt (LEVEL interrupts are not supported)...
void Rising( void )
  digitalWrite( 2, ! digitalRead( 2 ) );
void setup( void )
  attachPcInterrupt( 1, Rising, RISING );
The code is available here...
http://code.google.com/p/arduino-tiny/downloads/detail?name=PinChangeInterrupt-0001.zip
The readme.txt file is very sparse.  I simply don't have time to write up install / usage instructions.  If you get stuck, ask here for help.
Some instruction here (I'll try to get 16 MHz support published this weekend)...
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1285218245/25#25
Good luck and please let me know how you make out!
« Last Edit: February 11, 2011, 02:57:44 am by Coding Badly » Logged
Denver
Inactive - PM
I had good luck and this is how I made out . . .
The PinChangeInterrupt lib worked great! It even perfectly handled the FALLING mode.
I'm reading the IR remote every time and it had no effect on ISR0 so my I2C is working fine for the LCD display.
Major thanks CB. Thats a fine little lib.  smiley-grin
Here's the code FWIW. (The IR_ISR() may be worth taking a look at.)
/* ATtiny85 IR Receiver Test               BroHogan                        2/11/11
 * Tests IR receiver (using pin change interrupt) while I2C LC display is used.
 * SETUP:
 * ATtiny Pin 1 = (RESET) N/U                      ATtiny Pin 2 = (PB3) IR OUTPUT PIN
 * ATtiny Pin 3 = (PB4) to LED1                    ATtiny Pin 4 = GND
 * ATtiny Pin 5 = PB0/SDA on GPIO                  ATtiny Pin 6 = (PB1) N/U
 * ATtiny Pin 7 = PB2/INT0/SCK on GPIO             ATtiny Pin 8 = VCC (2.7-5.5V)
#include <PinChangeInterrupt.h>         // mimics attachInterrupt() but a PCI for ATtiny
#include "TinyWireM.h"                  // uses TinyWireM lib low level functions
#include <LiquidCrystal_I2C.h>          // for LCD w/ GPIO MODIFIED for the ATtiny85
#define GPIO_ADDR        0x3F           // (PCA8574A A0-A2 @5V) typ. A0-A3 Gnd 0x20 / 0x38 for A
// IR receiver defines
#define ENTER 12
#define UP    17
#define DOWN  18
#define RIGHT 19
#define LEFT  20
#define OK    21
#define POWER 22
#define SLEEP 55
#define INFO  59
// vars for IR_ISR() (must be global)
volatile boolean IR_Avail;              // flag set if IR has been  read
volatile unsigned int IR_Return;        // returns IR code received
volatile unsigned long ir_mask;         // Loads variable ir_string
volatile unsigned int ir_bit_seq;       // Records bit sequence in ir string
volatile unsigned int ir_string;        // Stores ir string
LiquidCrystal_I2C lcd(GPIO_ADDR,16,2);  // set address & 16 chars / 2 lines
void setup(){
  lcd.init();                           // initialize the lcd & TinyWireM
  lcd.backlight();                      // Print a message to the LCD.
  lcd.print("Hello, IR!");
  attachPcInterrupt(3,IR_ISR,FALLING);  // Catch IR sensor on PB3 with pin change interrupt
void loop(){
  Check_IR();
void Check_IR(){ // check if remote used and process
  int remoteInput;                      // normalized input from remote
  if(IR_Avail){                         // check if key on IR has been pressed
    remoteInput = IR_Return + 1;        // convert raw return to actual digit values
    if (remoteInput == 10) remoteInput = 0; // special case for zero key
    lcd.clear();
    switch (remoteInput) {              // a case for each key
    case 0 ... 9:                       // digits 0-9
      lcd.print("Digit-");
      lcd.print(remoteInput,DEC);
      break;
    case ENTER:
      lcd.print("Enter");
      break;
    case UP:
      lcd.print("Up");
      break;
    case DOWN:
      lcd.print("Down");
      break;
    case RIGHT:
      lcd.print("Right");
      break;
    case LEFT:
      lcd.print("Left");
      break;
    case OK:
      lcd.print("OK");
      break;
    case POWER:
      lcd.print("Power");
      break;
    case SLEEP:
      lcd.print("Sleep");
      break;
    case INFO:
      lcd.print("Info");
      break;
    default:
      lcd.print("????-");
    IR_Avail = false;                   // allow IR again
    digitalWrite(LED1_PIN, LOW);        // turn off LED
void IR_ISR(){ // This ISR is called for EACH pulse of the IR sensor
  if(ir_bit_seq == 0){                  // it is the long start pulse
    for(int i = 0; i<20; i++){          // see if it lasts at least 2 ms
      delayMicroseconds(100); // 100
      if(digitalRead(IR_PIN)) return;   // it's doesn't so get out (low active)
    ir_bit_seq = 1;                     // mark that the start pulse was received
    ir_mask = 1;                        // set up a mask for the next bits
    return;
  delayMicroseconds(900);               // wait 900 us and test
  if(!digitalRead(IR_PIN)) ir_string = ir_string | ir_mask;  // Stores 1 in bit
  ir_mask = ir_mask << 1;               // shifts ir_mask by one to the left
  ir_bit_seq++;                         // ir_bit_seq is incrimented by one
  if(ir_bit_seq == 12){                 // after remote sends 12 bits it's done
    ir_mask = 63;                       // only want the last 6 bits - the command
    ir_string = ir_string & ir_mask;    // only keep last 6 bits
    IR_Return = ir_string;              // final result
    IR_Avail = true;                    // indicate new command received
    digitalWrite(LED1_PIN, HIGH);       // turn on LED to show you got something
    ir_bit_seq = 0;                     // clean up
    ir_string = 0;
    ir_mask = 0;
    for(int i = 0; i<25; i++){          // delay to stop repeat 10ms / loop ~250ms about right
      delayMicroseconds(10000);         // 16383 is maximum value so need to repeat
~ Clifford Stoll
Dallas
Shannon Member
Excellent!  Thank you for the follow-up and thank you for posting your Sketch!
