Hi all,
we've been trying to get a GPS shield running. After a lot of effort, we are still looking at weird data in the serial monitor.
We are using this:
* EM-406A GPS module
* latest Arduino GPS shield (bought Nov 2010)
* Arduino UNO (ATMEGA 328)
* MacBookPro => MaxOS X, also tried with Acer => WinXP
* PC<>Ardunio: always connected via USB,
* Software: Arduino software utility on the PC(s).
We ran the
test program without a chip, simply forwarding the data from the GPS shield/module as descripted here:
http://www.ladyada.net/make/gpsshield/directconnect.htmlWe did the following tests/checks to understand what was going on:
1) double-check soldering:
looks good
2) tried all(!) baud rates:
concerning the settings in the serial monitor on the PC side, but we understood that 4800 should be correct => results: either garbage or (with too high baudrates) nothing
3) plug and unplugged TX, RX connections:
removing RX seemed to changed the data slightly, but to similar garbage, removing TX stop the data completely => everything as expected
And we keep seeing the weird data. At a baudrate of 4800, instead of the NMEA GPS values we are getting, this:
>9*$Ë9.&Ë9VËòrù.:ËéFËò*rÒÊËéFËø"VórÒÊË¢2¹>ÒNórÒÊËéFËø"NórÒRnN'Ë9*$Ë9Y2Ë9Y¹ù>>N
4) Later we mounted the chip and ran a little program to test the
Arduino<>PC USB connection (works fine!).
5) We also tried forwarding the data from the GPS module with a program running on the arduino, also works so-to-say: the arduino forwarded the garbage properly.
6) On the different forums we found people mentioning the binary mode. Since running in the binary mode is indicated by the LED shining dim (and no blinking!?), we don't believe to have our module in binary mode, but we tried out arduino code that was supose to convert the data from binary to NMEA. That also led to garbage only.
7) Also we downloaded the SIRF-Demo software (
http://www.falcom.de/support/software-tools/sirf/) to reset the GPS-module. This was suppose to put the module back into NMEA-mode in case it was in binary:
The SIRF-Demo also didn't seem to get proper data from the module. We tried to reset the module with the SIRF-Demo, but it didn't seem to have any effect. However we would appriciate it, if somebody could point out a step-by-step totorial on how to run the SIRF-Demo-software with the Arduino. Anyway...
Any help is welcome. Thanks a lot.
Cheers
Audiodroid
