Topic: Canique MK2 - an ultra low power Arduino board with onboard RFM69HW (Read 538 times) previous topic - next topic
canique
Canique MK2 is an ATMega328P based board that can be programmed just like an Arduino - with the same Arduino IDE. You only need an FTDI adapter to program it.
It is an ideal candidate if you need an ultra low power node that sends/receives data over big distances...
Optimized for Efficiency
The Canique MK2 is available in 2 versions: with voltage regulator or without - to make sure it consumes as little power as possible.
Power consumption via 3.3V without voltage regulator: ~4uA in sleep mode
Power consumption via >3.3V with voltage regulator: ~6uA in sleep mode
Run an Arduino with 1 AA battery?
By connecting a Canique Boost to the 3.3V power input of the Canique MK2 you can even make this board run with a single AA battery.
Connectivity
  • u.FL connector can be soldered onto the board
  • hole for antenna
  • optional 4MBit flash memory
  • optional RFM69W/HW on its back side
Quick Facts
  • Dimensions: 33 mm x 23 mm
  • Microcontroller: Atmega328P-AU
  • Stock speed: 16MHz (can be lowered)
  • Bootloader: Dual Optiboot is preinstalled, a blink sketch is programmed on the board
  • Max. voltage via "VIN" (Voltage Regulator): 13V
  • Range achieved: 1 kilometer
Shipped from Europe
It is shipped worldwide but especially easy to get in Europe since it is shipped from Europe.
Additional information and setup instructions
https://www.canique.com/mk2
How to order
https://www.canique.com/shop/mk2
