Topic: Arduino Tiny (Read 113048 times) previous topic - next topic
jopiek
#165
Mar 11, 2012, 09:17 pm Last Edit: Mar 11, 2012, 09:39 pm by jopiek Reason: 1
I'm using the arduino tiny software (http://code.google.com/p/arduino-tiny/) to try and control two servos with an ATtiny84. I have quite some timing problems as it seems to be. When I connect one servo to pin PA6 and use this software:
Code: [Select]
// Based on Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
// Changed by Johan
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int posMin = 17;
int posMax = 65;
  myservo.attach(4);  // attaches the servo on pin 4 to the servo object
  for(pos = posMin; pos < posMax; pos += 1)  // goes from posMin degrees to posMax degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  delay(3000);
  for(pos = posMax; pos>=posMin; pos-=1)     // goes from posMax degrees to posMin degrees
    delay(3000);
This works well...
However, I need to control two servos. Their position should be the same so I tried to connect them to one output. This makes the servos to jiggle with no avail. I also can't seem to get the servos work on another port.
I have tried using internal clock at 8Mhz and 16Mhz with an external resonator. Also capacitors.
Any ideas?!
Update:
Code: [Select]
// Sweep
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
Servo myservo2;  // create servo object to control a servo
int posMin = 17;
int posMax = 65;
  myservo1.attach(4);  // attaches the servo on pin 9 to the servo object
  myservo2.attach(5);  // attaches the servo on pin 9 to the servo object
  for(pos = posMin; pos < posMax; pos += 1)  // goes from 0 degrees to 180 degrees
    myservo1.write(pos);
    delay(7);
    myservo2.write(pos);              // tell servo to go to position in variable 'pos'
    delay(7);                       // waits 15ms for the servo to reach the position
  delay(3000);
  for(pos = posMax; pos>=posMin; pos-=1)     // goes from 180 degrees to 0 degrees
    delay(7);
    delay(3000);
this also works when connecting one servo to 4 or 5 but not when I connect two servos to either port.
Coding Badly
@jopiek:
One servo on one pin works?
One servo on one pin and a second servo on a second pin works?
Two servos on on pin does not work?
Coding Badly
Quote
Collect verbose output from an upload attempt and post it to the forum.
I get only one red line:
avrdude: stk500_getsync(): not in sync: resp=0x00
If you don't get a long sign-on message from avrdude it is not in verbose mode.
Quote
I'm using Arduino v0.22.
Hold down the Shift key when you click upload.
jopiek
@Coding Badly:
Almost:
A with one servo works (B no servo)
B with one servo works (A no servo)
Problems when:
1 connecting two servos to either A or B
2 connecting servos to A and B
stoopkid
Do I need to do anything special to get the 85 working at 128KHz? I had to comment out serial commands and I still get this error:
Quote
In file included from C:\Users\Nick\Documents\Arduino\hardware\tiny\cores\tiny\wiring.c:30:
C:\Users\Nick\Documents\Arduino\hardware\tiny\cores\tiny\/core_adc.h:55:4: error: #error Add an entry for the selected processor speed.
C:\Users\Nick\Documents\Arduino\hardware\tiny\cores\tiny\wiring.c: In function 'init':
C:\Users\Nick\Documents\Arduino\hardware\tiny\cores\tiny\wiring.c:257: error: 'ADC_ARDUINO_PRESCALER' undeclared (first use in this function)
C:\Users\Nick\Documents\Arduino\hardware\tiny\cores\tiny\wiring.c:257: error: (Each undeclared identifier is reported only once
C:\Users\Nick\Documents\Arduino\hardware\tiny\cores\tiny\wiring.c:257: error: for each function it appears in.)
This is my code, nothing fancy just sequencing the PWM:
Code: [Select]
int list[7] = {
  -1,-1,-1,-1,-1,-1,-1};
byte const set[7] = {
  B001,B010,B011,B100,B101,B110,B000};
boolean redo = true;
int x = 0;
int count = 0;
int count7 = 0;
int LED1 = 0;
int LED2 = 1;
int LED3 = 4;
int curVal[3] = {
  0,0,0};
int lastVal[3] = {
  0,0,0};
int nextVal[3] = {
  0,0,0};
void setup(){
  //Serial.begin(9600);
  //Serial.println("Reset");
  randomSeed(analogRead(0));
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  writeList();
      for (int i = 0;i<3;i++){
      nextVal[i] = (bitRead(set[list[0]],i)==1)? 255:0;
    //Serial.print(list[0]);
void loop(){
  for(int i=0;i<3;i++){
    curVal[i] = map(count,0,255,lastVal[i],nextVal[i]);
  analogWrite(LED1,curVal[0]);
  analogWrite(LED2,curVal[1]);
  analogWrite(LED3,curVal[2]);
  if(count==255){
    count = 0;
    if (++count7==7){
      count7 = 0;
      //Serial.println(" ");
      writeList();
      lastVal[i] = nextVal[i];
      nextVal[i] = (bitRead(set[list[count7]],i)==1)? 255:0;
    //delay(map(analogRead(1),0,1023,1,50) * 200);
    delay(200);
   // Serial.print(list[count7]);
  count++;
  //delay(map(analogRead(1),0,1023,1,50));
  delay(1);
void writeList(){
  int l = list[6];
  for(int i = 0;i<7;i++){
    list[i] = -1;
    redo = true;
    while(redo){
      x=random(7);
      if(list[x]==-1){
        redo=false;
        list[x] = i;
  if(list[0]==l){
    int y = random(1,7);
    x= list[y];
    list[y] = list[0];
    list[0] = x;
It works fine on any of the other attiny85 settings
thanks
Coding Badly
Huh.  I don't remember why I added that board option.  I know I didn't test it.  Oh well.
• Open core_build_options.h
• Change INITIALIZE_ANALOG_TO_DIGITAL_CONVERTER from 1 to zero.  The are of interest is...
   http://code.google.com/p/arduino-tiny/source/browse/trunk/hardware/tiny/cores/tiny/core_build_options.h#28
• Save and close core_build_options.h
Bear in mind that analogRead will no longer be available.
MGeo
Hello,
I am trying to compile a small test sketch for Attiny4313 using latest core and Arduino 1.0 IDE.  The sketch below compiles for Attiny2313, compiling under Attiny4313 throws an error:
unknown MCU 'attiny4313' specified
Known MCU names:
   avr2
   at90s2313
   at90s2323
   at90s2333
Is attiny4313 recognized in the (older) version of WinAVR included with ARDUINO 1.0, or am I doing something wrong?
Thanks,
George
Code: [Select]
/* Attiny4313 example (G.Small, 24Mar2012)
Example of Attiny4313 on Arduino Tiny core, with serial comms test
ATMEL 6 PIN ISP CONNECTOR TOP VIEW:
                MISO  1 |o o| 2  +Vcc
(SCL, to UNO A5) SCK  3 |o o| 4  MOSI (SDA, to UNO A4)
              /RESET  5 |o o| 6  GND
ATMEL AttinyX313/ARDUINO:
           (D 17) PA2  1|    |29  VCC
      RX   (D  0) PD0  2|    |19  PB7 (D  16)
      TX   (D  1) PD1  3|    |18  PB6 (D  15)
           (D  2) PA1  4|    |17  PB5 (D  14)
           (D  3) PA0  5|    |16  PB4 (D  13)*
      INT0 (D  4) PD2  6|    |15  PB3 (D  12)*
      INT1 (D  5) PD3  7|    |14  PB2 (D  11)*
           (D  6) PD4  8|    |13  PB1 (D  10)
          *(D  7) PD5  9|    |12  PB0 (D  9)
                  GND 10|    |11  PD6 (D  8)
* indicates PWM port
These arrays map port names (e.g. port B) to the appropriate addresses
for various functions (e.g. reading and writing)
#define LED_PIN           6                     // ATtiny Pin 8 (D6)
void setup(){
  pinMode(LED_PIN,OUTPUT);                      // for general DEBUG use
  LED_Blink(LED_PIN,2);                         // show it's alive
  int test = 31;
  Serial.print("test");
  LED_Blink(LED_PIN,1);                         // show it's alive
// LED blinker for status
void LED_Blink(byte pin, byte times){
  for (byte i=0; i< times; i++){
    digitalWrite(pin,LOW);
    delay (1000);
    digitalWrite(pin,HIGH);
    delay (1000);
Coding Badly
Quote
No.
Quote
Nope.  Compiles just fine.
There are instructions in the forum for upgrading to the latest version of WinAVR.  If you can't find them, let me know.
MGeo
Thanks once again for the help.  I updated my Arduino WinAVR.  I had to copy over avrdude.exe 5.11 and avrdude.conf from Arduino 1.0 folder to get my Pololu AVR USB Programmer to work but everything is now functional!
Thanks,
George
Kyrill
Quote
Quote
- delay() seems not to work on Tiny85 at 8Mhz (int. osc.). (might be Proteus simulation bug, but it works ok with HLT core).
By default, the Tiny Core uses timer 1 for millis on the ATtiny85 processor whereas the HLT core uses timer 0.  Timer 1 on the ATtiny85 is unique in the AVR world.  I suspect Proteus does not simulate the timer correctly.
I finally tried on real hardware, yes, delay() works ok, that's really a Proteus bug.
Quote
Quote
- Is it possible to run Tiny85 at 16Mhz using internal oscillator and PLL as clock source?
Yes.  I think the latest version has a boards entry for it ... yup ... http://code.google.com/p/arduino-tiny/source/browse/trunk/hardware/tiny/boards.txt#131
I've tried running both options - 8 MHz and 16 Mhz PLL - blink works ok on both, timing is correct.
But I ran into problem with Serial (one-way-tx-only). At 8 MHz it works ok. I even successfully ran TinyTuner. But at 16 Mhz PLL it doesn't work. Even at 9600 bps nothing is transmitted.
I use IDE v.1.0 and tiny core ver. 0012.
What do you think could be wrong?
An one more question: the guys mentioned a "modded" NewSoftSerial, could you give a hint where to find it?
One
Coding Badly
Excellent.  (that it works not that Proteus has a bug)
Quote
More good news.  Nice!
Quote
The stuff that comes with the Tiny Core?  Tiny Debug Serial?
Quote
Quote
[font=Courier New]  #if F_CPU <= 8000000L
   // port B bit 3 (PB3)
   #define TINY_DEBUG_SERIAL_REGISTER    0x18
   #define TINY_DEBUG_SERIAL_BIT         3
 #else
   // port B bit 2 (PB2)
   #define TINY_DEBUG_SERIAL_BIT         2
 #endif[/font]
A different pin is used at 16 MHz.  I assumed that a crystal or resonator would be connected.  You can either adjust the code above (in TinyDebugSerial.h) or use the alternate pin.
Quote
There was a discussion here in the forum.  Try searching.  If you can't find it, report back and I'll make an attempt.
Kyrill
Quote
Thank you. I preferred to edited the file. After OSCCAL adjustment it works perfectly, even at 115200 bps.
Kyrill
Dear Coding Badly
I've now run into another problem.
After studying the Attiny85 datasheet I'm tryin to utilize timer1 for precise pulse control.
I freed timer1 by modifying wiring.c (as you wrote earlier).
My intent is to be able to set precise pause length and pulse length of aech indiviual pulse.
I use following setup:
Code: [Select]
  pinMode(4,OUTPUT);  //needed for OC1B
  digitalWrite(4,LOW);
  pinMode(3,OUTPUT); //needed for myself
  digitalWrite(3,LOW);
  TCCR1 = 0b1000; // clock ck/128
  GTCCR =
    (1<<PWM1B) |
    (1<<COM1B1) | (1<<COM1B0) ;  // <<PROBLEM HERE
  OCR1B = 41;
  OCR1C = 100;
I need the pin to go low on OCR1C compare match and then go high on OCR1B compare match.
So according to above code I should get a pause of 41 ticks and then a pulse of 59 ticks and so on.
But something goes wrong. I get only a constant HIGH state on pin4.
I tried to use (1<<COM1B1) | (0<<COM1B0) instead, and it works ok (!), but the signal gets actually inverted, that's not what I need.
(0<<COM1B1) | (1<<COM1B0) also works ok, I get signal on two pins and one of them (pin 3) is "inverted inverted", thus suitable for me, but that wastes one pin (pin4), which I need to use as I/O, so that's not ok for me also.
Could you give a hint?
Coding Badly
I'll try to look more closely at it tomorrow but I believe you have to set CTC1 in TCCR1...
Quote
[font=Courier New]  TCCR1 =
      (1 << CTC1)
      | (0 << PWM1A)
      | (0 << COM1A1) | (0 << COM1A0)
      | (1 << CS13) | (0 << CS12) | (0 << CS11) | (0 << CS10);[/font]
Kyrill
The datasheet says that in PWM mode the counter is reset on OCR1C compare match regardless of CTC1 bit state. Anyway I already tried setting CTC1, that didn't help.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
