Topic: Arduino Tiny (Read 123999 times) previous topic - next topic
Coding Badly
dlar
Hi all,
I have a AtT4313 and want to use its inboard UART. When ever it try to upload the sketch it fails with this error:
Binary sketch size: 2350 bytes (of a 4096 byte maximum)
avrdude: ERROR: address 0x0810 out of range at line 129 of C:\Users\xxx\AppData\Local\Temp\build7553309411575013505.tmp\RX_Blink_ATT2313.cpp.hex
avrdude: write to file 'C:\Users\xxx\AppData\Local\Temp\build7553309411575013505.tmp\RX_Blink_ATT2313.cpp.hex' failed
Im trying to get a Serial LCD to display data. Here is the code:
const int CR = 13;
void setup(){
  for (int i=0; i<15; i++){
    Serial.print(CR, BYTE);
void loop(){
void LCDWrite(int s) {
  Serial.print("ad");
  Serial.print(s);
I know the Attiny2313 only has 2048 of flash but the Attiny4313 has 4096 of flash.
I have increased the size in boards.txt.
attiny2313at1.upload.maximum_size=4096
and i have updated the core to support the Attiny4313.
Can anybody help?
Thanks
leo72
Question about SoftwareSerial support. Is there any change to have the new SoftwareSerial lib that is shipped with Arduino 1.0 works with the last Tiny core 1.0? I tried today an example but I get some errors during compilation. Or should I continue to use the old NewSoftSerial modded to work with Tiny cores?
Coding Badly
@dlar: The Tiny Core has support for the ATtiny4313.  Just use the latest version.
Coding Badly
I don't know.  I believe the Arduino 1.0 SoftwareSerial is very very similar to the previous NewSoftSerial.  If they are similar then SoftwareSerial, like NewSoftSerial has to be modified to work on ATtiny processors.
There does not appear to be any new bug fixes and just one new feature...
http://arduiniana.org/libraries/newsoftserial/
http://code.google.com/p/arduino/issues/list?q=softwareserial
So, it looks like the best course is to continue using the modified "old" NewSoftserial.
leo72
The libraries are different. SoftwareSerial has been changed and if you download NewSoftSerial1.2 you can check that libraries don't match.
SoftwareSerial has taken the "write" method instead of "print" one, following the new trend of the Arduino IDE 1.0 but those methods conflict the some code in the tiny/cores/tiny/Print.h file.
I will try to use the "old" & modded NewSoftSerial1.2 instead of the SoftwareSerial.
leo72
#156
Feb 12, 2012, 04:21 pm Last Edit: Feb 12, 2012, 04:27 pm by leo72 Reason: 1
One question. Why did you remove the links to the old Tiny core from Google code?
Isn't it possible to download the old 0022 version?
Forget about it.... I had just to click on "deprecated downloads"  :smiley-sweat:
Osgeld
using linux mint I followed the instructions on arduinos page to install 1.0 on ubuntu, everything works fine until I hit the tiny, using the latest and greatest core I get the following
In file included from /usr/share/arduino/hardware/arduino/cores/tiny/WProgram.h:17,
                 from /usr/share/arduino/hardware/arduino/cores/tiny/Arduino.h:4,
                 from Blink.cpp:8:
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:629: error: 'TINY_DEBUG_SERIAL_REGISTER' was not declared in this scope
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:629: error: 'TINY_DEBUG_SERIAL_BIT' was not declared in this scope
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:629: error: template argument 1 is invalid
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:629: error: template argument 2 is invalid
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:629: error: invalid type in declaration before ';' token
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:630: error: 'TINY_DEBUG_SERIAL_REGISTER' was not declared in this scope
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:630: error: 'TINY_DEBUG_SERIAL_BIT' was not declared in this scope
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:630: error: template argument 1 is invalid
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:630: error: template argument 2 is invalid
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:630: error: invalid type in declaration before ';' token
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:631: error: 'TINY_DEBUG_SERIAL_REGISTER' was not declared in this scope
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:631: error: 'TINY_DEBUG_SERIAL_BIT' was not declared in this scope
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:631: error: template argument 1 is invalid
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:631: error: template argument 2 is invalid
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:631: error: invalid type in declaration before ';' token
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h: In member function 'void TinyDebugSerial::begin(long int)':
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:682: error: cannot convert 'TinyDebugSerialWriter_9600*' to 'TinyDebugSerialWriter*' in assignment
/usr/share/arduino/hardware/arduino/cores/tiny/TinyDebugSerial.h:686: error: cannot convert 'TinyDebugSerialWriter_38400*' to 'TinyDebugSerialWriter*' in assignment
while uploading a simple blink sketch ... help?
Coding Badly
Which board do you have selected?
Osgeld
attiny 84 @ 8 mhz
Coding Badly
I can't find any problems.
Did you get it from the Source tab, Downloads tab, or the Home tab?  Maybe one of the links is pointing to something out-of-date.
Osgeld
downloads tab
I think I figured it out, using the instructions here
http://arduino.cc/playground/Linux/Debian
under
Arduino 1.0 and Arduino UNO on Debian squeeze (6.0.3)
arduino would not work correctly, so looking back though what I did I installed arduino and arduino core from the normal repositories, which gives you version 18, then ran the above which gives you 1.0 functioning, but apparently it does not upgrade everything. I tried the version of tiny for arduino 19 and guess what, it works
least for me
so yea I have 1.0 as the IDE and apparently .18 for most of the core files ... !@*#$! linux
Kyrill
#162
Mar 10, 2012, 08:44 pm Last Edit: Mar 10, 2012, 08:58 pm by Kyrill Reason: 1
Hello, Coding Badly!
Huge thanks for your tiny core!
I've been playing around with a small sketch for Tiny85 (a multifunction 1-Wire slave). I'm not using real Tiny85 yet, but Proteus simulation.
I'm using Arduino v0.22.
At some point I started to get R_AVR_13_PCREL error on each compile.
Then I upgraded WinAVR according to your instructions in your post:
http://arduino.cc/forum/index.php/topic,51984.msg371307.html#msg371307
The error has gone and I accomplished everything I wanted.
Today I tried to write some code for Uno board. The code compiles without errors, but when uploading I get error:
avrdude: stk500_getsync(): not in sync: resp=0x00
I can only get rid of it after renaming the old backup "avr_old" folder back to "avr".
Does it mean, that I'll always need to use obsolete toolchain when working with Uno? Or I'm just doing someting wrong?
And 2 more questions:
- Is it possible to run Tiny85 at 16Mhz using internal oscillator and PLL as clock source?
- delay() seems not to work on Tiny85 at 8Mhz (int. osc.). (might be Proteus simulation bug, but it works ok with HLT core).
Coding Badly
Hello Kyrill,
You are welcome.
I have not had to.  I've been using the latest version of WinAVR since long before I created that post.  I use my Uno nearly everyday and have had no upload problems.
Could be.  Collect verbose output from an upload attempt and post it to the forum.
Yes.  I think the latest version has a boards entry for it ... yup ... http://code.google.com/p/arduino-tiny/source/browse/trunk/hardware/tiny/boards.txt#131
By default, the Tiny Core uses timer 1 for millis on the ATtiny85 processor whereas the HLT core uses timer 0.  Timer 1 on the ATtiny85 is unique in the AVR world.  I suspect Proteus does not simulate the timer correctly.
Kyrill
I get only one red line:
The behaviour of board LEDs is also different. When using old toolchain, after compilation finishes the board resets, then Rx/Tx LEDs flash several times (1/2 seconds for small 2K code), then the board starts to execute code.
With new version, after compilation the board only resets and starts old code execution. The arduino environment still waits about 20 sec with status "uploading", then displays the above described single red line.
By the way, I tried to upload to a Mega1280 board, erevything works ok with both old and new version.
That's cool, didn't notice version 0012 is out. Will definitely try it ASAP.
OK. Thanks for clarification.
