Pages: 1 ... 14 15 [16] 17 18 19   Go Down
Author Topic: Arduino Tiny  (Read 25940 times)
Dallas, TX
I have a couple of questions:
In the Tools > Board > ... menu in Arduino 1.0.1(OS X) there are several ATtinys listed but in the /Applications/Arduino\ 1.0.1.app/Contents/Resources/Java/hardware/arduino/boards.txt file there doesn't seem to be any reference to the ATtiny. Where is the boards.txt file for the ATtinys? I see the boards.txt file in /arduino-tiny-0100-0015 but that folder is not in my Arduino 1.0.1 application folder.
Question 2: In the boards.txt file from /arduino-tiny-0100-0015, there are references to files like "empty85at1.hex". What is in this file? It is obviously not empty.
Norfolk UK
I'm running windows and the boards.txt is in ..\hardware\tiny that also contains a folder for the empty bootloaders and the tiny cores.
The files are in effect a dummy bootloaders (they don't work), there purpose is purely to set fuses in the tiny devices that happens when you burn a bootloader from Arduino IDE.
thanks alot and if i use mega328  do i need to do bootload and stuff ?? because im new to this i dont know anything about that yet i need something easy like tiny so i just have to connect it with arduino pins derectly and setup and upload without making it any difficult thanks alot for help
Dallas, TX
The boards.txt file contains a few lines that contain the values for the fuses. It would not be necessary to have .hex file of several hundred bytes for that. There must be another answer.
Dallas
Shannon Member
With Arduino 0023 it was necessary to have an image to upload when Burn Bootloader was executed.
The "empty" images are all built with this...
http://code.google.com/p/arduino-tiny/source/browse/#svn%2Ftrunk%2Fhardware%2Ftiny%2Fcores%2Fempty
Dallas, TX
Ah, thank you!
Montevideo, Uruguay
Here is my software serial library for Arduino Tiny: http://www.pablogindel.com/images/SoftSerial.rar
Instructions in usage.txt file.
Regards,
P.G.
SE USA
@ssh0le
I have not really dug into it since its late, but what advantages are you seeing over the normal software serial library (I use soft serial on the 85 quite a bit)
Don't know what I do
A question redarding IDE 1.5.1
Both Arduino 1.0.x and 1.5 have been merged into IDE 1.5.1, that you can use to compile for Arduino UNO/MEGA/Leonardo and the new DUE.
I've tried to put the Tiny core inside the /hardware/arduino/avr/cores folder but it seems that it doesn't work. When I open the Tools/Boards menu I don't find the entries for the Tiny MCUs...
Dallas
Shannon Member
Both Arduino 1.0.x and 1.5 have been merged into IDE 1.5.1 ...
My attitude is, when it shows up here... http://arduino.cc/en/Main/Software ...it's official.  smiley-wink
That's not good.  I'll try to spend some time on it this weekend.  Thanks for the heads-up.
Leeds, UK
Once the magic blue smoke is released, it won't go back in!
I got it working fine with 1.5.1. I will post where I put everything this evening.
~Tom~
Yeah, but having both the UNO and the DUE, I needed to use the 1.5. When the 1.5.1 has been released, I read that it merged both branches, so I tried to program my Tinys with it.
Thanks  smiley-wink
Uhm.. good news for me.  smiley-grin
Montevideo, Uruguay
Advantages are:
- light weight
- less CPU usage
- you can use at *any* baudrate (i.e. 3600, 5115, etc.). Particularly suitable for low baudrates, since it not implement delay tables.
- better start and stop bit detections (i think... standard software serial library tends to hang for a long time when it loses sync and data arrives continuously).
- receive only (this may not be an advantage).
Leeds, UK
Put the tiny folder in the usual place (under the hardware folder). Then move the contents of the tiny folder into a subfolder named 'avr'. So for example my tiny files are located at:
...\arduino-1.5\hardware\tiny\avr
Then, copy the "platform.txt" file from:
...\arduino-1.5\hardware\arduino\avr\platform.txt
To:
...\arduino-1.5\hardware\tiny\avr\platform.txt
And voila, that should be all it takes. Restart the IDE and away you go.
The good news is that my fix for tiny85's and tiny84's to prevent errors when the compiled size is greater than 4kB still works in Arduino 1.5.1:
https://github.com/TCWORLD/ATTinyCore/tree/master/PCREL%20Patch%20for%20GCC
~Tom~
To:
I's thinking that the /avr folder should have some role in this, you confirm that I've seen right.  smiley-wink
This evening I'll try your suggestions  smiley-wink
I don't have this issue because I use Linux with the last 3.4.1 toolchain from Atmel.
Pages: 1 ... 14 15 [16] 17 18 19   Go Up
