Topic: Brand new Uno - can't upload anything to it (Read 6411 times) previous topic - next topic
wossname
It seems that many people have seen the error messages I'm getting but not two threads about it seem to have common solution or even explanation of what the problem is.  In my case I can no longer upload to either of my UNOs!
Looks like my new UNO has broken my uploading capability...
1 - Uploaded the Blink sketch to my old arduino UNO - worked fine.
2 - Unplugged old arduino UNO and plugged in a brand new one straight out of the box.
3 - Upload FAILED for new UNO.
4 - Changed back to old Uno and upload FAILED.
The new one does have a boot loader installed because the light flashes as you would expect.  I can't even flash a new bootloader on there.
Whatever I try to upload I always get this message:
Code: [Select]
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
James C4S
What operating system?
Are you able to upload if you manually reset the board right after "Sketch Size" message?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Terry King
Are rechecking the COM port in IDE "Tools" ??
Every new Arduino seems to create a DIFFERENT Com port number, and you have to check every time you plug in a different Arduino....
Also?? What Operating system??
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com
wossname
#3
Feb 12, 2011, 09:40 pm Last Edit: Feb 12, 2011, 09:45 pm by wossname Reason: 1
Windows Vista.  I have been paying attention to the COM ports the whole time.  Weirdly, my old Uno board has started working again for no apparent reason.  The new one that caused this issue in the first place still doesn't work.  Interestingly though the old arduino always shows up on COM1 and the new (bad) one comes up on COM3, but even observing this I'm still getting that same annoyingly unhelpful error message I mentioned in the first post.
Pressing the reset button at various times has no effect in solving this.
So I tried all this in Fedora 14...
After a lot of faffing around with groups and permissions and the stupid preferences file, I managed to get code uploaded to both Unos, but the sketch does not execute properly on the chip after uploading, the Blink sketch just sits there with the "L" light on all the time and never blinkks at all.
I've scoured the troubleshooting pages on the website but they don't cover this at all.
Is this something to do with 8u2 firmware?  I've seen some mentions of that but not sure if it applies in this case or not?
Terry King
That message means the downloader software in your desktop (AVRDude) can not handshake with the BootLoader code that it expects to answer nicely on the arduino.
So I THINK the dependencies are:
1- USB Cable
2- Driver / .inf for the USB interface on the arduino (For the particular Operating System).
3- Working USB interface on Arduino  (FTDI or in this case the 8U2 Atmel micro doing the USB, and IT's firmware.)
4- Working ATMEL 168/328 chip on Arduino
5- Working Bootloader software on Arduino 168/328
Does anyone have a procedure for dividing and conquering this common and frustrating problem??
@wossname you have covered 1 and 2 with your substitution approach.
You might cover 4 and 5 by physically SWAPPING the 328's on the two Arduinos. UNLESS you have a SMT version.
Keep us posted; this needs to be better understood.
At least by me... :smiley-roll:
wossname
#5
Feb 12, 2011, 10:35 pm Last Edit: Feb 12, 2011, 10:36 pm by wossname Reason: 1
I'm reluctant to swap the 328's around because they seem to be tough to get out of their sockets and I dont; want to damage them or the boards.
This is my output if I hold <Shift> while clicking  the [->] upload button...
Code: [Select]
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "C:\Users\......(censored).......\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM3
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude done.  Thank you.
mellis
Where'd you get the new Uno (that's giving you problems)?  When it appears in the Device Manager, is it shown with a warning icon (yellow triangle, I think)?
How are you uploading to the new board on Fedora?  Over the USB cable?  If you upload the blink sketch, does the LED ever go off / on (e.g. after 20 seconds or more)?
If one Uno works and another doesn't with the same USB cable, computer, and installation of Arduino, it's likely that there's some problem with the new board.  You should probably just contact your distributor and get a replacement.
retrolefty
Quote
One method to help divide and conquer troubleshooting this kind of problem is to perform a loop back test on the USB serial converter chip (either the older FTDI chip or the newer 8u2 chip). If one jumpers ground to reset pin that will hold the 328 processor in reset condition. Then jumper pins 0 and 1. Now open up the Arduino IDE, then plug in the Arduino and if the 'new' comm port shows up, select that port # and then one can open up the serial monitor. Whatever is send from the monitor's send window should echo back to the monitor's receive window. This at least isolates the problem to a bad AVR chip/missing bootloader, or something in the serial communications path.
Lefty
wossname
#8
Feb 13, 2011, 11:07 am Last Edit: Feb 13, 2011, 11:40 am by wossname Reason: 1
I both my Unos from www.proto-pic.co.uk, which is a sparkfun subsidiary as far as I can tell.  Seems a good place to get stuff usually, the staff are helpful and quick, which is why I went there the second time, even though the old arduino (which works perfectly) had some bad solder joints on it which I had to fix myself.  As for the Device Manager, there are absolutely no tell-tale differences between one Uno and the other, apart from that they always "prefer" different COM ports.  I've only got one USB cable so I've never had them both plugged in together.
Yeah I'm always using the USB cable, as I don't have any other tools available (programming boards or whatnot).
[fedora only...]
I was fiddling with the sketch code last night.  The code is always broken when it gets onto the bad Uno BUT it seems I can alter the way the LED lights up.  I cannot get it to run the void loop() function more than once - it's as if it's instruction pointer isn't being incremented after it's returned from the second line of C code.  If I go pin HIGH, then delay(1000); then pin LOW the LED stays lit forever.  If I reduce that delay to 1ms then the LED lights for what looks like a few milliseconds and then goes off forever.  Not sure what is going on there.
[/fedora only]
I'm not sure I agree with that on all levels.  From my own point of view as an angry consumer I think most people would just want a new one... but from the Arduino project's point of view wouldn't you rather find out what wrong with the product?  If I send it back to proto-pic it'll end up in a scrap bin with a post-it note on it saying "broken".  I'm happy to try and help diagnose this very aggravating problem if you clever technical chaps are willing to help me with some instructions. :)
wossname
I've just tried the "loop back" test that Lefty mentioned.  The Arduino IDE's serial terminal seems to show the exact same behaviour for both boards (see screenshot below).  However when I hit enter the good Uno flickers it's TX/RX lights as you'd expect, but the bad Uno does not.
I even tried reseating the 328 chip in it's socket and that doesn't seem to have made any difference, can't say I'm surprised, that was desperation more than anything :)
Terry King
#10
Feb 13, 2011, 01:17 pm Last Edit: Feb 13, 2011, 01:22 pm by Terry King Reason: 1
OK the loopback seemed OK. But that small difference does seem to point to SOME difference in the two USB micros.
Personally, I would get the antistatic bag an Arduino came it, sit the two Unos on it and use a small screwdriver back and forth a few times, slowly lifting on each end of the 328's and swap them...
wossname
That probably is the sensible thing to do but as it stands, I have 1 fully functioning Uno and 1 non-functioning Uno.  I don't want to risk wrecking my good one by combining it with bits from a bad one if you see what I mean.  Can't really afford to do that.
mellis
Dunno, I'm running out of ideas.  May be a strange (and rare) manufacturing defect.  You could try playing a bit more with uploading different programs under Fedora, e.g. ones that send data over the serial port, or turn on other pins, etc.  But it sounds like something is maybe holding the 328 in a weird reset state.
wossname
I wonder just how rare it is given the number of people complaining of upload problems with the Uno recently.
I won't be buying any more Arduinos for a while in any case.
58606
#14
Feb 13, 2011, 05:55 pm Last Edit: Feb 13, 2011, 06:03 pm by 58606 Reason: 1
Code: [Select]
[code/]
I got this error earlier today! In the Arduino software, look under Tools - Board and make sure it's set to Arduino UNO. It should work fine.
EDIT: Sorry, I just noticed that on the first line, my error was resp=0x00, not resp=0x30. Maybe it's still the same problem?
const bool loveElectronicsRelatedThings = true;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
