waveform viewer for PC (free, for windows)
Hallo,
I have a simple DIY dataloger that works this way:
1/ the arduino board: samples 2 analog channels, 10bit resolution, 100ms sample speed, and runs about 1 hour.
2/ the data are sent to PC over RS232 line
3/ the data are saved to one big file as ASCII .csv file by printf() function in Processing
Now I'm looking for any waveform viewer for PC (free, for windows) that can load and show data as graphical output.
Have you tried OpenOffice Calc, spreadsheet? - http://download.openoffice.org/
  • can read CSV
  • can handle 65000 lines (less than Excel)
  • has graphing features.
  • has a macro language to automate some actions
  • and free.
Another option I think is GNU-plot , quite powerfull see - Category:Gnuplot diagrams - Wikimedia Commons
dowloadable from - gnuplot download
gnuplot looks fine. I will try it. Thank you.
If you already have Excell, you can draw graphs of the results on there. Using gobetwino, you can probably save the results directly to the Excell file. Although it might not be what you are after, you could try...
Gadgets og teknologi | Dansk Tech Blog - Mikmo (gobetwino)
Onions.
I will second the vote for gnuplot. I have found it fussy to install, but quite flexible and powerful once I got it going. You can see my project here: Pretty pictures from my electricity and bandwidth data « Projects
Excel is fast to get started with, but you will run out of rope fairly quickly, and it can't be automated in any simple way.
this project will take data through serial in real time and plot it (scope!). There is a corresponding Arduino sketch so in order to get your project working with it one or the other would need to be modified.
http://code.google.com/p/xoscillo/
