Loading...
Pages: [1]   Go Down
Author Topic: Help getting started  (Read 1154 times)
Venezuela
Offline Offline
Jr. Member
The less You explain, the more I understand
View Profile
Hi everybody. Sorry but where I come from it´s extremely difficult to get electronic supplies. Can I use either of these to run Arduino: ATtiny45 or Ttiny2313? Thanks, Alberto.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Do you have an ICSP?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
You can always order from the dozens of sites (ebay included) that sell electronics for hobbyists (including Arduinos).
Logged
Venezuela
Offline Offline
Jr. Member
View Profile
I don´t have a credit card, shipping would x10 and nobody does that type fo favor due to the fact of $400 limit per Year; I can get these two locally.
I plan to build everything myself, using my parallel port foe ICSP.
Can I run Arduino on these, please?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Quote
I don't think so, at least no easily . You can see the list of "arduino" (or compatible) boards in the menu Tools/Board of Arduino IDE.
Logged
Sweden
Offline Offline
Full Member
Arduino = The Best
View Profile
WWW
Quote
What do you mean with "no easily"? I finished this some days ago: http://www.instructables.com/id/Arduino-on-all-sorts-of-Atmels/
alah: With the help of that you should be able to use many different ATtinys /ATmegas etc.
JanD
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
JanD,
Great tutorial, thanks for that.
By "not easily", I mean that one needs to be pretty knowledgeable to do that.
Just by burning a bootloader on a avr and supporting it in Arduino IDE, does that make it an Arduino?  For example, do we expect the Ethernet shield to work with the an "Arduino" with ATtiny?
Logged
Sweden
Offline Offline
Full Member
Arduino = The Best
View Profile
WWW
JanD,
To do easy things like setting an output or reading an input or similar should be done pretty easy even without much knowledge, but things like the ethernet shield etc. are of course not so easy to use, even with Mark's core files.
JanD
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
As long as you have a way to program them...
Quote
...which you will, then the answer is "yes".  You will need a "core".  There is a list of available cores here...
http://code.google.com/p/arduino-tiny
Notes...
The 2313 has very little SRAM.  You will be restricted to very simple applications.  The 45 is an improvement but even it is rather limited.  You may want to find someone in the U.S. (or neighboring country) who is willing to barter for a handful of 85s (or 84s or whatever suites your needs).
It is unlikely that an Arduino library (like Servo) will work on a Tiny processor without modifications.
Logged
Sweden
Offline Offline
Full Member
Arduino = The Best
View Profile
WWW
Quote
Quote
Notes...
I do NOT want to start a fight with you, Coding Badly, but with the help of my tutorial on instructables you can program many AVR MCUs. There are other core files out there other than the ones from Coding Badly and Mark Sproul (witch are used in my instructable), so choose the ones you think are the best. I use Mark's because they have support for many different MCUs, not only ATtinys.
JanD
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
@alah did not ask about "many AVR MCUs".  He asked a specific question about two specific tiny processors.
When @alah has his tools in place, your tutorial will make an excellent starting point.
Quote
If you had taken the few seconds necessary to follow the link I posted you would have found that the opening page of the website includes a list of cores appropriate for tiny processors including Mark Sproul's core.
Quote
His core is incomplete for tiny processors.  There are much better choices available.
Logged
Sweden
Offline Offline
Full Member
Arduino = The Best
View Profile
WWW
Quote
I meant more generaly.
Quote
I have already taken some time to look at your site, but I don't think if I need to repost the links.
Quote
I must say you are right with that, but the way Marks core files (and the new with that the new ones released with the new IDE) are made on register basis, meaning it's easier to add more MCUs. Can be that your core files are that too, but I haven't looked at them more than with a glance.
JanD
Logged
Venezuela
Offline Offline
Jr. Member
View Profile
OK Coding Badly, florinc and JanD:
First of all, THANKS.
As a newbie, I´ll need to start with small and simple projects like flashing two LEDs with two buttons to START and STOP ( I know it can be done with just one button ).
So that´s only 3 or 4 I/O pins. Speed isn´t any problem at this time, 10 MHz is fine.
I´m going through JanD´s instructable and I can get an ATMega88V.
I´m following ITP PhysicalComputing ´s instructions, so hopefully I should have my LED blinking by next week! I´ll let You know how I´m doing. Thanks again, Alberto .
Logged
Pages: [1]   Go Up
Print
Jump to:
