Loading...
Pages: [1]   Go Down
Author Topic: Controlling a dimmable T5HO ballast - OSRAM Quicktronic QTi 2x28/54 dim  (Read 1741 times)
Offline Offline
Newbie
View Profile
I need to control a dimmable ballast for T5 H0, it's an OSRAM Quicktronic QTi 2x28/54 dim.
How do I do that ? And what's needed on its inputs (see attached photo) ? I don't have a manual, I'm not that good at electronics. It looks like it wants some 0-10v, as the Arduino only provides 5v, do I just have to find a schematic to "double the voltage" ?
Thanks in advance guys,
        Xav
Logged
Australia
Offline Offline
Newbie
View Profile
Looks as if you control  it with a variable voltage fro 0V to 10V.
If this correct controlling it with an Arduino will not be straight forward.
You will either need to use a DAC to get varying voltage or generate a voltage using PWM and some resistors, capacitors and transistors.
The DAC is probably the simplest method for generating a varying voltage. Then you will need a transistor based circuit to level shift the voltage.
Get onto Google. Research DACs, see what is available. Check transistor amplification etc.
Good luck
Logged
United States (Texas)
Offline Offline
God Member
Arduino socks
View Profile
a DAC seems like overkill. check out this post where they discuss exactly what you are doing
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1216381158/5#5
Logged
Offline Offline
Newbie
View Profile
Thanks for your answers.
Now a basic non-Arduino question: I plugged the lamps on the ballast, and the ballast on the mains, but lamps don't light.
I tried putting a 1.5V AA battery on the 0-10v input, but still nothing.
How can I test the ballast easily ?
Thanks,
        Xav
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Connect 9V battery.
And I agree with weirdo557, don't use a DAC, it's too much.
Logged
Pages: [1]   Go Up
Print
Jump to:
