Topic: Memory issue? (Read 2788 times) previous topic - next topic
pjchant
Hello,
as an exercise I've written a sketch to take ascii data in on the serial port on an Arduino Uno and convert it to Morse code.  I'm finding that if I comment out some of the code in a routine producing help text it works, if not commented out, it does not.  The code is here:
http://petezilla.webdev.fire/public/embedded/arduino/morse
(too long to sensibly post in the forum).
The block of code I've commended out runs from lines 256 - 278.
I'm wondering if the micro-controller is running out of memory?  I've produced the sketch with no particular regard for memory useage.  However, the code resides in program memory, not SRAM, so I'm not certain it is a SRAM issue.
Thoughts?
Groove
Link is broken/incomplete
Per Arduino ad Astra
koenwar
Are you in the default arduino environment programming?
If so, you can see in the bottom of the screen how large your sketch is and how much memory available is.
Are you dynamically allocating memory with malloc functions?
Groove
If you have any large tables that aren't defined as being in PROGMEM, then they will use RAM.
Graynomad
To find out what RAM is being used
open a DOS window
navigate to the build folder, (to find this hold SHIFT while compiling your code). The path will be something like
C:\Users\<yourname>\AppData\Local\Temp\build3014820664802798593.tmp
run
avr-size <yourprogname>.cpp.elf
You'll get a result like this
   text    data     bss     dec     hex filename
   1010       0       9    1019     3fb <yourprogname>.cpp.elf
If data and bss add up to anything like maybe 1800 (hard to tell what, it depends on the program) you're in trouble
______
Rob
pjchant
Sorry, I'm an idiot, that link was to the off-line (dev) version of my website.  Correct link is:
http://www.petezilla.co.uk/public/embedded/arduino/morse
Specifically:
http://www.petezilla.co.uk/public/embedded/arduino/morse/morse7.pde
Graynomad
With the code commented out
9656     760     201   10617    2979 blink.cpp.elf
with code included
9860    1550     201   11611    2d5b blink.cpp.elf
That's 1751 bytes of RAM used not counting the stack. It's getting in the dodgy area.
Try just removing a few lines to see if that fixes the probem.
______
Rob
pjchant
I have used a number of strings, using the string object.   They are not especially large, but on the other hand there is not a lot of SRAM.  The code I comment out to make things work is in the serial routines, with fixed strings.
Given that my variables are altered during the course of running the program it would not be a good idea to use PROGMEM I would have thought.   I wonder however whether putting the help information below into a variable stored in program memory might help.  Another solution, probably the best, would be to put it into the EEPROM.  However, I'm not sure if there is a way that data could be included in the sketch.  I assume I'd have to upload it separately.
However, I'm assuming it is a memory issue - am I right?
Routine below:
void help() {
 Serial.println("~");
 Serial.println("~USB ASCII to Morse converter.");
 Serial.println("~Help:");
 Serial.println("~ ##H: Print help (upper case H).");
 Serial.println("~ ##1: Rate 5 words per minute");
 Serial.println("~ ##2: Rate 10 words per minute");
 Serial.println("~ ##3: Rate 15 words per minute");
 Serial.println("~ ##4: Rate 20 words per minute");
 Serial.println("~ ##5: Rate 40 words per minute");
 If the following is not commented out then the arduino produces no
 output.
 Serial.println("~Add # to the end of a line to repeat message.");
 Serial.println("~A # before any letter omits spaces to they can be run-");
 Serial.println("~together to generate prosigns, e.g. #CT (start of message).");
 Serial.println("~Carriage return (13) causes message to be transmitted.");
 Serial.println("~Commands and Messages:");
 Serial.println("~Lines beginning in tilde ~ are information");
 Serial.println("~Prompt for user input is >");
 Serial.println("~Messages:");
 Serial.println("~    <Ready    =    Awaiting commands or data.");
 Serial.println("~    <Sending  =    Sending morse.");
 Serial.println("~    <Wait     =    Please do not send data, buffers near full.");
 Serial.println("~    <Overrun  =    Too much information in buffers.  Contents ");
 Serial.println("~                   deleted without being sent.  Send data again");
 Serial.println("~                   in smaller chunks.");
 Serial.println("~Basic idea is you send data, when a <Wait is received then");
 Serial.println("~continue passing current word then hit return to send chunk");
 Serial.println("~before sending more data.");
 Serial.println("");
pjchant
with code included
______
Rob
Interesting, with the help commented out as below I can send 10 characters but with 20 it hangs.  I suspect that this is it running out of memory - perhaps a buffer over-run type problem, not that I have a fixed length buffer, but I do have finite ram.
void help() {
  output.
  Serial.println("");
James C4S
This is not the case.  This message is the amount of Flash (or program) storage being used and what is left.  It has nothing to do with the RAM at Runtime.
It is entirely possible to have a sketch that takes up 15k of Flash/Program Memory and only use a couple hundred bytes of RAM.
AWOL
All those Serial.print strings are wasting RAM - move them to PROGMEM.
pjchant
You mean something  like the string demo in:
http://www.arduino.cc/en/Reference/PROGMEM
From what you are suggesting then, if I have a line:
Serial.println("Hello world!");
then the complied program puts "Hello world!" in RAM, uses it and does not release it?  Just curious.
AWOL
How could it "release it"?
pjchant
Perhaps a bad choice of words.  However, the implication that my many Serial.println command consume RAM implies that those RAM locations are not reused. I.e.
Say "Hello World" is written to memory locations say 100-110 (decimal).  These are now output to serial.
Now I want to send to the serial port "Hello  world again" that implies that instead of writing from program memory to RAM "Hello World Again" in memory locations say 100-116 that it is writing them in locations 111-127.  100-110 is not being re-used.  Seems odd to me.
Pete
James C4S
It would stand to reason that the complier would only store one copy of a constant, but I do not know if this is the case.  In your code each of your string constants are different.
The complier does not know how many times a constant (string or otherwise) will be used (what if there was a loop?), so the constant has to be stored in RAM at all times.
By moving the (string) constants into PROGMEM, you never actually copy the constant into RAM.
