Loading...
Pages: [1]   Go Down
Author Topic: Dc Motor Control  (Read 397 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello
I planning to control 2 dc motors via arduino. The Motors are 12v
Motors draws about 30amps and the other about 10amps
I have to be able to control speed and direction.
Does anyone have schematics for a circuit i could use to drive either of these motors
Thanks
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Google can find a lot of h-bridge schematics, some good and some bad. You will probably be better off buying an h-bridge kit like below instead of trying to roll your own.
http://secure.oatleyelectronics.com//product_info.php?cPath=94&products_id=827&osCsid=30093449b694ae247d94c2bcce5d0560
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Overijse, VL
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
I thought of making my own motor controller (found some different tutorials after some time with google - like this one http://freecircuitdiagram.com/2009/02/01/pwm-motor-control-circuit/ ) but in the end I just bought a dual motor driver from Pololu. I am very happy with it and it is simple to interface with. It controls two 5amp motors. Note the difference of a motor driver and a motor controller! Drivers are more basic but achieve the same reuslts. But for 30amp motor you should use a high-power driver which can control only one motor. Pololu has some 25amp (continuous) models but you pay about 50 dollars for it... a driver for a 10amp motor is a bit less but still 40 I think. They all can control speed and direction and you can add a heatsink if you want to reach more amps in continuous operation.
« Last Edit: February 13, 2011, 02:24:36 pm by Fons1302 » Logged
Chester, UK
Offline Offline
Sr. Member
Trying to return the love to none logic level MOSFETS
View Profile
I'm guessing that you have a 360w motor? If it's anything like the ones I've used then it's stall current will huge and so will its inrush so assume the worst.  I'd plan on it drawing  it drawing more like 40A when running too as the 360w may be its hp output.  If you can afford it I'd recommend the OSMC.  I am looking to order one myself very soon.  They also sell some controllers for small motors.
Logged
If your system involves lethal voltages/life critical/flamable elements - you probably shouldn't need to ask.
The Arduino != PC.
Pages: [1]   Go Up
Print
Jump to:
