Topic: Arduino Duemilanove-Can't Upload (Read 1 time) previous topic - next topic
58606
Feb 13, 2011, 05:22 pm Last Edit: Feb 13, 2011, 05:32 pm by 58606 Reason: 1
Help! I'm trying to upload a sketch (1536 bytes) to my Arduino Duemilanove. Whenever I try to upload, I get this message:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
EDIT: On one, it doesn't show any error messages, but the TX light on the Arduino stays on, and it seems like it's frozen.
EDIT TO MY EDIT: I looked at the serial monitor, and discovered that there's an infinite loop in my previous program! How do I stop it? Do I have to wipe the MCU and put the bootloader back on?
This happens on both of my Arduino Duemilanoves :smiley-eek:! One of them has never been used until now. I'm using the latest version of the Arduino software (0022) on a Windows 7 64 bit machine. I would appreciate any help I get on this subject! =(
Here is my sketch:
Code: [Select]
 Sketch Author: xxxxxxxx
 Date Started: 2/12/2011
 Date Finished: TBD
 Desc: This sketch detects how many (not which) buttons are
 pressed, and displays that number on the 7 segment display.
//define pin numbers
//7 segment display
const int a = 2;
const int b = 3;
const int c = 4;
const int d = 5;
const int e = 6;
const int f = 7;
const int g = 8;
//buttons
const int b1 = 9;
const int b2 = 10;
const int b3 = 11;
const int b4 = 12;
//define varables
int b1State = 0;
int b2State = 0;
int b3State = 0;
int b4State = 0;
int numPressed = 0;
 pinMode(a, OUTPUT);
 pinMode(b, OUTPUT);
 pinMode(c, OUTPUT);
 pinMode(d, OUTPUT);
 pinMode(e, OUTPUT);
 pinMode(f, OUTPUT);
 pinMode(g, OUTPUT);
 pinMode(b1, INPUT);
 pinMode(b2, INPUT);
 pinMode(b3, INPUT);
 pinMode(b4, INPUT);
 if (digitalRead(b1) == HIGH) //find out if button 1 is pressed
   b1State = 1;
   b1State = 0;
 if (digitalRead(b2) == HIGH) //find out if button 2 is pressed
   b2State = 1;
   b2State = 0;
 if (digitalRead(b3) == HIGH) //find out if button 3 is pressed
   b3State = 1;
   b3State = 0;
 if (digitalRead(b4) == HIGH) //find out if button 4 is pressed
   b4State = 1;
   b4State = 0;
 numPressed = b1State + b2State + b3State + b4State; //add up how many buttons are pressed
 switch (numPressed)
   case 1: //displays the number 1
     digitalWrite(a, LOW);
     digitalWrite(b, HIGH);
     digitalWrite(c, HIGH);
     digitalWrite(d, LOW);
     digitalWrite(e, LOW);
     digitalWrite(f, LOW);
     digitalWrite(g, LOW);
   case 2: //displays the number 2
     digitalWrite(a, HIGH);
     digitalWrite(c, LOW);
     digitalWrite(d, HIGH);
     digitalWrite(e, HIGH);
     digitalWrite(g, HIGH);
   case 3: //displays the number 3
   case 4: //displays the number 4
     digitalWrite(f, HIGH);
   default: //displays the number 0
[code/]
const bool loveElectronicsRelatedThings = true;
James C4S
Serial loops tend to cause this problem.
You need to manually reset the Arduino immediately before the code upload begins.  Click the upload button and when you see the message like "Sketch size:  xxxx bytes (out of xxx bytes)" press the Arduino's reset button.
The timing might vary (like 1-2 seconds after the message.)
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
58606
Thanks for your help, but it turns out it was a simple problem. The software was trying to upload to an Arduino Uno! I fixed it in Tools - Board and it uploaded perfectly.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
