Loading...
Pages: [1]   Go Down
Author Topic: Embedded PC Won't Boot With Arduino?  (Read 428 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
I'm building a solution that uses an Arm-based embedded Linux PC (a Technologic TS-7553) with an Arduino (currently using a Duemilanove).
The Arduino is powered by the USB port. If the Arduino is plugged into the USB when power is applied to the PC, the PC will not boot.
While searching the forums, I found information regarding when the Arduino was powered separately, but I haven't found any people having problems booting with the Arduino powered by USB. I tried a powered USB hub, which didn't seem to make any difference.
I'm thinking this sounds like it may be a problem with the PC, and I also have a query into the manufacturer. But I'm wondering if anyone here may have some guidance. I'm much more a programmer than an electronics expert, so any guidance is appreciated!
Neal
Logged
Northern California (by San Francisco)
Offline Offline
Full Member
View Profile
I'm using an Arduino plugged into (via a USB cable) and thus powered by a BeagleBoard running Ubuntu Linux. It boots up fine.
I suspect it's a problem with your BIOS. When a computer boots up, sometimes it tries first to boot from a USB port, thinking that there is a pendrive or hard disk there to boot from. When it finds something on the USB port,even though that something is not a boot device, it hangs.
I've had that happen to me in Windows with a USB wireless mouse dongle. I've not had it happen in Linux. But I suspect that may be your problem.
« Last Edit: February 13, 2011, 01:25:31 pm by Daanii » Logged
The Netherlands
Offline Offline
Full Member
Beep!
View Profile
Some USB host controllers can act like this.
I have the same with my PC at home, when I plug in anything that draws power from the USB connection, it will not start up succesfully. When I switch the device off/unplug it from the USB port, it works fine.
Logged
Copenhagen / Denmark
Offline Offline
Edison Member
Do it !
View Profile
WWW
If the embedded PC has a BIOS option for booting from USB, try to disable it.
Logged
Pages: [1]   Go Up
Print
Jump to:
