Topic: temp conversion via analog input (Read 2046 times) previous topic - next topic
GolamMostafa
Check that the root program works and the correct temperature value appears on the Serial Monitor.
After that you can always connect 7-segment display unit which could be my version or of the Ada-fruit one.
In my area the Ada-fruit one is not available; so, there is no opportunity at the moment to play with it and help you in this regard.
Regards,
LandonW
I have my full circuit working.....mostly, I don't think the math is working. I tried it on a calculator and it didn't seem correct, here is my full code, I labeled things a little different but I think it should be the same yes??
Code: [Select]
#include <Adafruit_GFX.h>
#include <Adafruit_SPITFT.h>
#include <Adafruit_SPITFT_Macros.h>
#include <gfxfont.h>
  This is a library for our I2C LED Backpacks
  Designed specifically to work with the Adafruit LED 7-Segment backpacks
  ----> http://www.adafruit.com/products/881
  ----> http://www.adafruit.com/products/880
  ----> http://www.adafruit.com/products/879
  ----> http://www.adafruit.com/products/878
  These displays use I2C to communicate, 2 pins are required to
  interface. There are multiple selectable I2C addresses. For backpacks
  with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
  with 3 Address Select pins: 0x70 thru 0x77
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
int tempSensor = A2;
const byte fanA = 7;
const byte fanB = 8;
int tempSensorV;
float realTemp;
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
#include "Adafruit_LEDBackpack.h"
Adafruit_7segment matrix = Adafruit_7segment();
  pinMode(fanA,OUTPUT);
  pinMode(fanB,OUTPUT);
#ifndef __AVR_ATtiny85__
  Serial.println("7 Segment Backpack Test");
#endif
  matrix.begin(0x70);
  digitalWrite(fanA,LOW);
  digitalWrite(fanB,LOW);
  tempSensorV = analogRead(tempSensor);
  realTemp = 316.3114 - 56.0655 * (5/1024) * tempSensorV;
  if (realTemp > 195){
    digitalWrite(fanA,HIGH);
  else {
  if (realTemp > 215){
    digitalWrite(fanB,HIGH);
  else {
  // try to print a number thats too long
  matrix.print(10000, DEC);
  matrix.writeDisplay();
  // print a hex number
  matrix.print(0xBEEF, HEX);
  // print a floating point
  matrix.print(realTemp);
  delay(2500);
  // print with print/println
  for (uint16_t counter = 0; counter < 9999; counter++) {
    matrix.println(counter);
    delay(10);
  // method #2 - draw each digit
  uint16_t blinkcounter = 0;
  boolean drawDots = false;
  for (uint16_t counter = 0; counter < 9999; counter ++) {
    matrix.writeDigitNum(0, (counter / 1000), drawDots);
    matrix.writeDigitNum(1, (counter / 100) % 10, drawDots);
    matrix.drawColon(drawDots);
    matrix.writeDigitNum(3, (counter / 10) % 10, drawDots);
    matrix.writeDigitNum(4, counter % 10, drawDots);
    blinkcounter+=50;
    if (blinkcounter < 500) {
      drawDots = false;
    } else if (blinkcounter < 1000) {
      drawDots = true;
      blinkcounter = 0;
    delay(10);
GolamMostafa
Quote
Which math seems to be not working?
